Computers & Internet Logo
Question about Acer Computers & Internet
Can I use deferent AC adaptor for Acer aspire 5920
Posted by Ibrahim mahama on
Steve Pack
  • Acer Master
  • 6,351 Answers
You can as long as polarity and voltage is the same.
Posted on Jan 28, 2023
My Asus Laptop won't turn back on, there is a chemical smell, and my adaptor green light brinks
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the Acer Aspire 5920 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
My Acer aspire 5750z wont turn on. I have plugged the AC adaptor in and all I get is a nlue light a the from of the laptop. If I take the battery out adn then plug in the adaptor, I don't get an
I have several starting problems with my Acer Aspire. To start with,my On Switch doesnt work so I removed the strip cover and use a matchstick (the non-red end) to push the round black dot in a small square at the extreme top right- hand corner above the keypad. Sometimes it's my adapter lead which works with other laptops so I figure it must be the laptop connection. I keep wiggling the adapter lead close to the laptop connection and push it in hard. My lead is the rotating kind so I try very hard not to move it once connected. Also because I"ve removed the start cover. I have to softly clean the connectors at the top lefthand side and the right.
Hope one of these things help you and you don't have all three problems as I do.
My acer 5920 wont charge or wont work on ac adaptor but the ac adaptor works fine on my friends laptop
Either the AC port on the back of your laptop has a lose connection - if operation without battery is an issue, or if battery charge only is issue - then battery may have to be reseated or it is at end of life. Test by removing battery and running AC alone. if connection port is bad, laptop will power off immediately/unexpectedly. Good luck! btw - batteries for this unit are around $40 on ebay
No power and the adaptor etc. is working okay
if the battery is old it may need to be replaced
have the voltage checked on that first
2answers
My acer laptop 5920 just went off and now won't
Obiviously It is the problem of the connector of the power adapter.
Acer 5920 -The power suddenly went off.
Probably this is due to surge current happend in the circute, butter not to switch on your lap. consult the service centre. Its is better not use the same adaptor for more troble shooting.
1helpful
Aser Aspire 5920 Will Not Switch On
it must b some problem with the RAM......get the ram changed ...den it will work fine
2helpful
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
7helpful
3answers
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Steve Sweetleaf
Steve Sweetleaf
shadow
