To fix the dim brightness level, remove the battery and pull the plug out of the mains power. Leave it disconnected for at least 5 minutes then plug it back into mains power. You should find the brightness has retuned to normal. I have 3 of these Clock Radios and the picture attached shows the comparison between dim and normal. For some unknown reason they intermittently decide to dim themselves. This may be why Sony included a dimmer in the next model up ICF-C318. Anyway I hope this helps
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
I just got a similar model at Big Lots a few months ago. A T439S. There some funky stuff they do with those displays it could be that the lamp is wearing out. 7 years is good life for them.
A-ha! Those manuals sure do come in handy sometimes. I found the solution. In addition to functioning as a snooze button for delaying the alarm, the snooze button is also a brightness button for the time. If you press snooze one time it changes the time brightness from bright to dim, press it again and it goes from dim to motion sensitive only, press it again and it returns to bright.
I just tried this and resolved my problem. I hope it helps you as well. Enjoy!
