What powers that side of the fuse box ? Do you know ? Do you know what a power distribution diagram is ? You need to look at a diagram to see where those fuse's get there power ! Could be only powered when the ignition switch is on ! Suggest you view wiring diagrams . Do you know how to do electrical testing ? With a volt meter . Electric Testing Techniques You Need to Know
Enter vehicle info year , make , model and engine size . Under system click on electrical distribution , under subsystem click on power distribution . Click the search button , then click on the blue link. Look at the second diagram down . You'll see a IGN SW - BATT 2 30 amp fuse powers the ignition switch .In the on position the ignition switch powers the under hood fuse box . are you testing with the key on ? You also have a right instrument panel an a left instrument panel fuse box , do you know about these ? What is your main problem ? No start ?
its the airbox beather connect it to the spout on the engine wen the bike is running you should fill air comming out of the spout pop the tube back on and just cable tie the pipe on
Open up the front shroud (unhook batteries first) and switch the wires going to the throttle pod, its just 2 thin wires and if they were switched already you will probably be able to switch them back. The throttle pod is what the thumb throttle lever is hooked up to.
