Question about Canon PIXMA Office Equipment & Supplies
Canon Pixma E400. Unable to scan?
Scanner is not working?
Sharifullah
    Habit-Forming:
  • 103 Answers
If you are unable to scan with your Canon Pixma E400, you may need to update the printer's software. You can download the latest software from the Canon website and install it on your computer. Once the software is installed, you should be able to scan documents with your printer.
Posted on Jan 29, 2023
ADMIN Andrew
    Top Expert:
  • Canon Master
  • 57,269 Answers
Question edited for clarity and spelling, 'Canon' one 'n' and toss in some CAPS.
Check 1: Make sure that your scanner or printer is turned on. Check 2: Connect the USB cable to a different USB port on the computer. Check 3: If the USB cable is connected to a USB hub, remove it from the USB hub and connect it to a USB port on the computer.
E400 series : Scanner Does Not Work - Canon : Official Manuals
More
https://www.google.com/search?q=Canon+Pixma+E400.+Unable+to+scan
Cannon scanner pixma s it's not scanning
TRy checking your cable between the scanner and computer. If you have spare try changin wire, it could be a problem with the wire or connection is not good.
Hi I have a Cannon MP 160 how do I get the doco to scan?
so simple
open the photoshop then click import then usb scanner then it will open the scanner window
2answers
Can't figure out how to scan my picture from the scanner directly to my computer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-10
Same problem Microsoft document scanner cannot see scanner
did you change o/s //some cases you need a different driver/check their home page(cannon)//oz
5helpful
3answers
Cannon mp160 scanner does not work- do not have original CD
use this link here I had the same problem the printer and copier was working fine then I had to click the software and add the software for mp navigator to scan... u can also get drivers for the printer on the same page for anyone who has lost the orginal cd it came with... now it works fine
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
3answers
Scanning
hi,
593
PIXMA 150 PRINTER AND SCANNER
Update Drivers http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=12764#DownloadDetailAct
What Scanner software are you using?
Was it created to work with Vista?
Otherwise you could purchase, new scanner software such as Nuance ScanSoft OmniPage 16, right now you can get it with Paperport 11 added in for FREE.
Problem with Scanner
I am not sure if you have tryed this or if it will work yet I had this problem and did the following: Went to: Cannon Utilities MP Navigator 2.0 or other version Preferences Select Cannon Product using
Clive
Clive
old marine
old marine
