Televison & Video Logo
Question about Universal Remote Control Televison & Video
I need codes and instructions for a RCU600WMS 1504P remote ?
I'm trying to use it on my Magnavox TV from 2007 it's a flat screen. Any help would be appreciated. I need the codes and the instructions and how to do it .I've never set up a universal remote control before.
Posted by Ben Cramer on
  • Universal Re... Master
  • 6,611 Answers
The user manual for the RCA RCU600WMS is available here: https://www.rcaaudiovideo.com/remote-code-finder/?sku=RCU600WMS&productType=TV . The manual includes some codes. For others, you need the revision number which is inside the battery compartment of the remote. Note: the RCU600WMS manual is from 2001. Thus the included codes in the manual will be for devices manufactured before 2001 (~6 months before the remote was programmed). 1504 was not a value in the available list of revision numbers on the RCA code site. Most of the revision codes were 5 digit numbers.
I hope this helps.
Posted on Jan 27, 2023
2answers
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
I cant turn the tv off or on, but i change change channels and the volume.
I know the website you need--click the link at the end of my answer, then select your model # (RCU600WMS) from the drop-down menu...you'll find codes/manual for any TV you try it with! >>CLICK HERE
1helpful
I cannot program program this universal remote to use it with a Sharp TV.
http://www.retrevo.com/support/RCA-RCU600WMS-Universal-Remotes-manual/id/402dj594/t/2/ provides a downloadable manual for your remote.
The TV codes for a Sharp TV are 173, 095, 171, 004, 006, 012, 029, 111, 112, 113, 12 in case a "Code Search" from your remote doesn't extract and/or store the codes.
Hope this helps.
Is an RCA remote control RCU600WMS compatible with a Norcent TV? If so,what is the code?
There is no published code for the Norcent TV on the RCU600WMS. I would follpow the instructiions on the left margin of
http://www.rcaaccessories.com/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_UNIVERSAL_REMOTES
to find the code.
Please rate this solution. Thanks.
1helpful
Code for Magnavox Univ remote
Try one of these codes:
018, 021, 023, 071, 085, 090
If those don't work, respond with the model for the remote and we'll try some others. Also, if remote requires 4 digit codes, just put a 0 in front of each of the above.
Code for a Panasonic TV/VCR
Hello, Urpurdy -
Am I safe to assume you have the user manual (in printed / paper format) for the RCA RCU600WMS remote control? If you do not, you can find it and download and save the PDF document here: https://voxxintl.zendesk.com/hc/en-us/articles/225306867-Information-User-Manual-and-Code-List-for-the-RCA-RCU600WMS-Universal-Remote-Control . You can then print it from the saved document. Tip: I suggest you set up a file folder in your computer Documents folder, titled: RCA TV Remote (or something like it, so you can find it whenever you may need it.) Also, I print the user manual out and keep it near the TV for future reference.
The user manual includes the programming instructions and code lists starting on page 6 (PDF page 4).
Best wishes.
24helpful
7answers
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
2helpful
2answers
Need code or instructions
DO U HAVE THE CODE FOR THE URC 4220? MY TV IS A ILO
31helpful
6answers
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Top Universal Remote Control Televison & Video Experts
Jaime Hernandez
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
