Washing Machines Logo
Question about Speed Queen Washing Machines
I just got my new Speed Queen Washer and I am having the same issue of fabric softener staying at the bottom of the tub. Have tried different amounts of fabric softener and no luck.
Having same issue of fabric softener at the bottom of tub. Have tried putting in lesser amount and no luck. What am I doing wrong?
Posted by Catherine Buhr on
ADMIN Andrew
    Top Expert:
  • Speed Queen Master
  • 57,072 Answers
Is the water turned on? That is impossible!
Posted on Jan 29, 2023
2answers
Speed Queen top load washer fabric softener
Please check that you added the softener to the correct compartment of your washer. Also, please read or re-read the instructions for adding the fabric softener. Once you've done those 2 things, please run a test wash with clothes that you would not particular care about potentially staining. Thank you.
1helpful
3answers
Fabric softener dispenser is not dispensing the fabric softener until after the wash is completely finished
I have the exact same problem, Speed Queen washer, top loader. The machine still has some fabric softener in the cup, but the more irritating problem is the puddle of softener underneath the finished load. I had bought a SQ because they seemed old school and I thought it would mean problems would be simpler to repair.
2helpful
6answers
Fabric softener in bottom of tub
Mine machine is brand new..so the dispenser is not dirty..I have lots of softener left in bottom all sliming my clothes
10helpful
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
2answers
When the spin cycle begins the washer vibirates and moves on the floor. After the spin cycle reaches the maxium speed it stops. The springs are fine, but what else could be wrong?
The machine is probably not leveled properly. To level the machine, partly fill it with water. Make sure that the drum is standing in the middle of the machine and then adjust the machine until the water is at the same level all around at the nearest set of holes to the water. Check that the drum is still in the center of the outer drum. Make sure that the adjusting feet are all firmly on the floor and that you cannot rock the machine at all by hand. A top loader must be 100% level or it will shake.
White residue on clothes
Common usage things to check:
  1. Detergent formulation
    Make sure you're using high quality detergent that contains both sodium carbonate and aluminosilicates. They'll be listed on the ingredient list.
  2. Amount of detergent
    The detergent amounts given on the usage label of the detergent box are for average water hardness (4-9 gpg). If your water is harder than average, or if your clothes are really dirty, you'll need to use slightly more detergent than what's recommended on the box. If you have really hard water, you may need to add a packaged water conditioner to each load, such as Calgon® or Spring Rain®.
    If your water is softer than normal, you'll create too many suds, which will retain gookus. In this case, you'd use slightly less detergent than recommended on the box.
  3. Cold water washing
    If you wash clothes in cold water only, the cold water should be in the range of 65-75F. If it's too cold for your hands to comfortably be in the water, it's too cold to activate the detergent.
  4. Overloading
    After the washer is loaded with clothes and then filled with water, there needs to be enough head room in the tub for the clothes to swish around in. A properly loaded washer has clothes loosely placed in the tub up to the top row of holes.
  5. Rinse-added fabric softener
    Some fabric softeners and detergents have a chemical reaction that can create white deposits (also called 'gookus') on the clothes. Try switching brands of fabric softeners or detergents or not using fabric softener at all for a couple of loads.
10helpful
5answers
LG WM0642HW smells bad. We leave the door open when not in use to dry it out and air it out. But the smelliness is getting worse.
There have been lot's of reports of moldy door seals. Check your door seal at the bottom to see if it is holding water and not draining properly. Dry and clean with a bleach solution is it is. Front loaders don't always drain completely. WHen you start a new cycle the first thing they do is purge any water left from the previous one. This also causes a mold issue. Easiest solution is to do a stain cycle with presoak and add 2 cups of bleach to kill the mold. Obviously no clothes! Good luck!
2helpful
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Fabric softener is left in bottom of drum after wash cycle completes
We had the same problem. You have to remove the part that the softener goes in and clean it. You will be amazed at how much build up is in there. That solved the problem for us.
Top Speed Queen Washing Machines Experts
Marvin
Marvin
Paul Bade
Mike
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
