Cameras Logo
Question about Konica Cameras
I have a Konica Z-up 70, and it hardly turns on. I have a new battery in it and the date on the back comes on, but not the camera. It has worked twice randomly, but other than that wont turn on
Posted by Natalie Smith on
Pawel Nietyksza
    Master:
  • 318 Answers
It sounds like there could be an issue with the power supply of your Konica Z-Up 70. I suggest trying to reset the camera by removing the battery and then replacing it and turning it back on. If the issue persists, you may need to contact a qualified technician for further assistance
Posted on Jan 29, 2023
1helpful
4answers
Everytime I turn on my camera it asks me to set date/time. It goes to the default date/time setting of 00.00.0000 00:00 mm/dd/yy. What do I do to set the date/time so that it permanent? The photos are...
It takes around four hours for a freshly charged main battery to charge the internal backup battery. It you do that and it still doesn't charge it, you need a new internal battery. The fully charged internal battery in most of them will hold the charge for up to 3 weeks with the main battery out of the camera.
1helpful
Camera won't stay turned on
If you need it you can get the user manual on this link; http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z1/D_Z1_E.pdf The hard reset involves dismantling the camera and un-soldering the memory/clock back-up battery from the main board (check page 112 under batteries). This battery needs replacing after around 3-5 years and is the most likely cause of your problem - they recommend getting it done at an authorised service centre which is good advice unless you have a lot of technical skill - quite a fiddly job to do and to get to - also professional tools are recommended in order not to damage the camera. Konica Minolta have now passed service responsibility for this camera to Sony - please post back with your location and I can try to find a convenient service centre. The back-up battery in question is probably relatively cheap (you would have to get the serial number from it for me to check for sure), but the labour involved in replacing it may possibly make the replacement a bit costly, but still should be much less than a new camera of the same quality. Hope this helps :)
I have a Konica Minolta Maxuum 4, how do you turn off the date on the camera? I am in a film class and my teacher told me I need to figure out how to turn it off for class purposes.
Press the DATE button on the back of the camera to cycle through date, time, and none (just dashes). Press the shutter release button to set the format.
If you need a manual, you can download one at
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_4/2164_E_B.pdf
Konica Revio KD-400Z. Internal battery appears to have expired meaning I have to reset date etc. each time I remove either the l-ion battery or the SD for downloading. Can I fit new internal battery and...
First the bad news. Konica got out of the camera business in 2006...all service is now handled by Sony. The internal battery is not user replaceable. It is a rechargeable battery that recharges itself from the regular battery. It takes about 3 hours to accomplish this. If you remove the main battery for 24 hours, the internal completely runs down and all date and time settings are lost. If after setting them again, you don't leave the fully charged main battery in the camera for at least 3 hours, they will disappear again.
3helpful
Can't set the date polaroid a500
It looks like the date battery has dried out, check your user manual and try to replace with a new button battery.
Konica Minolta 7D
It was nice to be able to help another. I noticed the post that her 7D would not turn on. It seems just before Konica Minolta stopped there camera business they had a serious problem that was not passed around or corrected. Your expensive 7D camera does not turn off when you take off the lens. When you put another back on while the camera is still on it will fry out a circuit board or sensor. That will cost ya about $300.00 to repair.
I thought I would let her know how to prevent it from happening again. I have done this twice now. My 7D is in repair. I figured out why it does that. Wish they could have told me.. Had to learn the hard way. Also wish they could put a better resister in the camera or have an auto shut off switch. Would make more sense ..
2answers
*ist-D date/time setting problem
I had exactly that problem with my first *ist D. Replace the AA batteries and the time was always lost. A new 'button' battery didn't fix the problem. The camera was replaced. The second camera had to be returned too. While I was with the dealer he told me my first camera wasn't really faulty as Pentax UK had been able to tell him how to fix it by some routine. I must admit I didn't listen hard to what he said, I was more interested in getting my hands on the third camera - and then the fourth when that didn't work either.
Top Konica Cameras Experts
Tom Chichester
Tony Parsons
Tony Parsons
Pawel Nietyksza
Are you a Konica Camera Expert? Answer questions, earn points and help others
