Heating & Cooling Logo
All pro SPC 150T propane heater. starts and runs great for 10 minutes and then shuts heat down and blows only cold air. let sit for time and it repeats process.
Propane tank has plenty of propane. using 5-gallon propane tanks.
Posted by Hank tanks on
Pawel Nietyksza
    Master:
  • 318 Answers
It is possible that the problem with your All Pro SPC 150T propane heater could be caused by a faulty gas regulator or pressure switch. The gas regulator controls the flow of propane while the pressure switch controls the temperature of the heater. You may need to replace the gas regulator or pressure switch in order to get your heater running again. Additionally, you could also check for any loose connections or clogs in the fuel line.
Posted on Jan 30, 2023
155,000 BTU propane heater only blowing warm air on all settings?
Question edited for clarity and typos.
Question moved from Cars and Trucks category.
FULL 'make model (what it is)' in all questions please, first 3 words.
Generic answer - Clean the jets, check the thermostat, check gas pressure.
3helpful
My heater ignites but goes out within a minute or two.
This tells me the flame sensor is bad. When it heats up it separates causing the unit to shut off. You should replace this and it will resolve the problem.
Thanks and have a great weekend.
Could i run this with an inverter with my disiel truck? I have a 400 watt inverter
If the wattage of the heater does not exceed 400 watts then you certaily can. Just watch that you don't run down your battery if you intend to shut off your vehicle.
When I push my red button in it shut off the fuel and wont stay going
this is caused by a bad thermo coupling. just to make sure that it is in fact bad - hold down the button for about 20 seconds while the heater is going and if after that amount of time the unit still shuts down when you release the fuel button - then replace the thermo coupling.
c...
The heater wont start got power,got propane ,when i release the push in switch it wont start
YOU WILL NEED TO HOLD THE START BUTTON FOR ABOUT 2 MINUTES, ON YOUR FIRST START UP , TO GET THE FRESH GAS UP INTO THE UNIT
2helpful
Where can i find a parts breakdown for this heater spc-85
I plug a Thermostat in The power line to break the power when at temp. Once I start the heater using the reset button,when temp is reached and the themo calls for heat just the blower comes on only. I have a All Pro propane 50,000 to 85,000 btu heater thanks Ron
Heater runs for 20 minutes then shuts off
These heaters have built in thermostats. Sometimes they are adjustable sometimes they are not, check to see if your is adjustable and see if this fixes your problem. Also check to see if there is any air restrictions possibly causing the heater to over heat.
All pro spc-85
going through the backplate to the nozzle location is the thermocouple. it is a copper like tube that sits back from the actual flame. if you are looking for a replacement go to www dot desatech dot com.
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
