How do I assign a line on my Panasonic KX-TS3282B corded 2-line phone so the red lights stop flashing?
It's a refurbished phone that came with no manual, and I cannot find the anwer anywhere. I hooked it up, and I can make and get calls, but the flashing red lights on all lines are driving me nuts. Thanks.
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
After you connect the AC adapter the display shows Set Clock for 60 seconds and all of the extension indicators flash until you assign the extension number of your unit.
Even if you do not use the intercom, assign the number otherwise all of the extension indicators will continue flashing.
Contact your line provider the system cannot see the lines , if you have ISDN lines these should show a green light on each and should be solid when connected and flash if disconnected
It's a trick. Assign the button, then press PROG the button, and dial 2 then 9, or whatever your access code is for an outside line, then the number and ENTER. You can press more buttons and dial more numbers, or press EXIT to quit.
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
This phone is a system phone. it is intended for use with a PBX, not to be directly connected to a phone line.Do not directly connect or you run the risk of damaging the phone.
