Microwave Ovens Logo
Question about GE Microwave Ovens
GE profile advantium 120 display out, no operation but turntable runs when closed
I have a GE profile advantium 120 PSB1201NSS01 microwave from 2009. Display is out, no oven operation but the turntable runs when the door is closed. The display and operation worked a few times when closing the door and flickered when I was checking the door switches. I figured it must be bad switch so I replaced them but still no display or operation. But the turntable still runs when closed. Pushing the touchpad I can hear faint clicks. Any ideas? Prior to this answer, I was thinking relay board so I took it onto look at. Confirmed part number and reinstalled the relay board and the unit worked. A few days later it went out again but the turntable wasn’t turning on its own. Then this morning the display was on like everything was ok. It ran for less than 30 seconds, everything shut down and then came back on with power failed while cooking message. The same thing happened again after about 5 seconds and then it ran for 3 minutes until we stopped it. Everything seems ok again. I haven’t seen reference to that error message anywhere yet. I’m not sure what to check. Still go to cut out switches?
Posted by James Pinto on
SojaTech
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Check for continuity across temperature cut out switches. Sometimes the connector (shovel plug) is defective.
Next is the printed circuit board: (1) Look for bad solder joints and (2) check the MGT relay. It is on the PCB and has 2 shovel plugs on the top.
"closing door, flickered when checking the door switches" = Loose connection somewhere.
Posted on Jan 29, 2023
Testimonial: "Prior to this answer, I was thinking relay board so I took it onto look at. Confirmed part number and reinstalled the relay board and the unit worked. A few days later it went out again but the turntable wasn’t turning on its own. Then this morning the display was on like everything was ok. It ran for less than 30 seconds, everything shut down and then came back on with power failed while cooking message. The same thing happened again after about 5 seconds and then it ran for 3 minutes until we stopped it. Everything seems ok again. I haven’t seen reference to that error message anywhere yet. I’m not sure what to check. Still go to cut out switches?"
  • SojaTech Feb 09, 2023
    You indicated: "turntable runs when the door is closed." So at times, this turntable is running and nothing else works. This would probably be a stuck relay on the control board.
    When all power fails on the unit, it has to be either the thermal cutout switch, door interlock microswitch, or some other safety device. It could also be the connectors on these sensors/switches. If the connection is a bit loose, it may conduct electricity and then fail when a higher current is demanded.
    If your OK with working on live equipment, use a insulated poker (dry chopstick) to move wires/connectors inside. See if you can isolate the problem without being electrocuted.
    If you don't find a loose connection or defective thermo-switch then you're left with the control board. In that case, recomend going on NextDoor.com or a garage sale and look for a 'free microwave' that isn't working. You can save the switches from your current uW oven as spare parts.
    Some of the microwave oven are just dirty and can be cleaned by boiling a cup of water in the oven. I see many for sale under $20, not worth purchasing a $100 circuit board to fix your current oven.
    Best of luck to you!
Ge profile advantium 120 stopped working
Barbara I highly recommend contacting GE directly at 1-800-433-2682 or go to www.geappliances.com Marcus
My GE Profile Advantium 120 microwave sparks when I try to sterlize a kitchen sponge
Wayne,
If your sponge has any metal in it, that would be the cause of the sparking. The only other thing that could cause sparks is grease built up behind the wave guide cover or the magnetron is going bad.
I have a GE profile advantium oven 120 that is just over 1 year old the turntable rotates but as soon as I put on the glass or mental tray it will not rotate what is the problem?
Either the coupler is cracked, the motor is defective, or the turntable support ("rotating ring asm") is worn or defective.
The service manual is here and you can find links to helpful exploded view diagrams and order parts here.
4helpful
2answers
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
1helpful
2answers
Arcing
My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
3helpful
2answers
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Open Questions:
Top GE Microwave Ovens Experts
vince
Marvin
Marvin
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
