Kitchen Ranges Logo
Question about Stoves Kitchen Ranges
Wolf cooktop 2005 model ct36 e ser# 1157479. double burner not working
I left water boiling on double burner on high for an hour till pot was dry forgot to turn it off. I reset breaker several times. When I turn just that burner on burner control lights blink five seconds and go off. Burner is warm to the touch. When i turn on any or all of the other burners and then turn on faulty burner the control blinks continuously and burner is warm to the touch. if I turn off any other burner while faulty one is blinking it then goes off and I hear an audible click near burner controls. Thanks for listening.
Posted by savvy on
I have a wolf electric cooktop model CT36. The problem i have is the burner triple zone works on second and third zone but do not work on the first zone. What can i do? thank you very much
www.ettusaislashes.com/siberian-mink-lashes/ Siberian Mink Lashes without wearing Siberian Mink Lashes Eyeliner painted so beautiful China best False eyelashes manufacturer promote wholesale price 3d mink eyelashes, our Siberian Mink Lashes is 100% handmade, more natural design and easy to apply. We accept Service OEM/ODM for 3d mink eyelashes with individual business logo. Luxury glitter customize box is always available. Shop your love style.
http://www.ettusaislashes.com/siberian-mink-lashes
May 09, 2018 • Cooktops
1helpful
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Hi, We have a GE profile cooktop (JGP975SEK1SS ). Last night, the boiling water spilled on the bottom right burner, so I turned off the stove. But since then every time we turn on the stove, the two...
Hi shadnaz,
A common issue with water causing the problem. I'd suggest following my below Tip on fixing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it
Aug 08, 2011 • Cooktops
2helpful
My electric igniter keeps sparking
Hello, Did you clean the cooktop recently? Sometimes water or cleaner can get into the spark switch causing it to spark untill it dries out. The same if a boiling pot spills. If none of those happened one of the burner switches is bad.
1helpful
MY wife boiled over her tea pot of water and now the pilots on all four burners continue to click as if you turn on the gas to light the stove.
The water has shorted out at least one of the igniter switches. Disconnect power to the unit and let it dry out for several hours and it should be just fine.
2helpful
One burner on gas cooktop fires up but goes tick, tick tick.
There may well be water in the burner. It will evaporate in a day or two. Then it will work fine again.
please mark this answer as a fixya
Boiling liquid ran down into ignition switch, now light stays on
is this the front right burner? i looked at one yesterday where milked spilled into it.it burnt out the little board under the know. i am not sure of the model # on the one i worked on.
1helpful
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
1helpful
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Top Stoves Kitchen Ranges Experts
Paul Carew
mark warfield
mark warfield
ADMIN Andrew
ADMIN Andrew
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
