Car Audio & Video Logo
Question about Kenwood Car Audio & Video
Why not show CD track info on Kenwood c-h7 using dp-mh5 player? what error ? what should check?
Alex Urzica
    Novelist:
  • 59 Answers
The issue with not showing CD track information on your Kenwood C-H7 using the DP-MH5 player could be caused by several factors. To resolve this issue, you can check the following:
  1. Compatibility: Ensure that the DP-MH5 player is compatible with the Kenwood C-H7 unit.
  2. CD format: Ensure that the CD is in the correct format and meets the requirements for playback on the DP-MH5 player.
  3. CD read error: Make sure the CD is clean and free of scratches, as these can cause read errors that prevent track information from being displayed.
  4. Connections: Check the connections between the DP-MH5 player and the Kenwood C-H7 unit to make sure they are secure and properly connected.
  5. Software/firmware: Make sure that both the DP-MH5 player and Kenwood C-H7 unit have the latest software/firmware installed and are up to date.
If these steps do not resolve the issue, you may need to seek further assistance from the manufacturer or a professional repair service.
Posted on Jan 29, 2023
Testimonial: "Thanks for your answer. As per your answer, my player may be software/firmware make this issue. Coz every cd insert and play this player music is play and can listen the sound, only not show the track of CD. Is it can solve by myself? Please advise."
I have a Kenwood Multiple CD Player DP-M993 6 Disc Player and need to know the Unit Number for the Remote Control
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjXgKW8mOr6AhWFpokEHR7dCO8QFnoECA8QAQ&url=https%3A%2F%2Fwww.vintageshifi.com%2Frepertoire-pdf%2Fpdf%2Ftelecharge.php%3Fpdf%3DKenwood-DPM-993-Owners-Manual.pdf&usg=AOvVaw3Egktp5e2PKVgF8ppDrztX
My dad has a kenwood multiple compact disc player dp-mh5 that the disc tray randomly won’t open on, any suggestions on what to try?
Hello Skye, the Kenwood Multiple Compact Disc Player DP-MH5 of your dad, has a problem with a strap inside the mechanism, I suggest you take it to a specialized technical service
If you have technical knowledge, I send you the link to download the service manual, on page 16, the breakdown of the mechanics appears and shows you the belt with the number 46, that is the one that you must replace
I also sent you the link to download the user manual
Greetings Franco Dosil
Hola Skye, la Kenwood Multiple Compact Disc Player DP-MH5 de tu papa, tiene un problema con una correa dentro del mecanismo, te sugiero que la lleves a un servicio tecnico especializado
Si tu tienes conocimientos tecnicos, te envio el link para descargar el manual de servicio, en la pagina 16, aparece el despiece de la mecanica y te muestra la correa con el numero 46, esa es la que debes reemplazar
Tambien te envio el link para descargar el manual de usuario
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-DPMH-5-Service-Manual.pdf https://www.manualslib.com/manual/203920/Kenwood-Xd-8551.html?page=17
1helpful
Kenwood dp-mh5 suddenly out of power while listening to radio. No power seems to reach. What might have happened suddenly?
See if radio has an inline fuse may be have one and is blown. use 12 volt test light to see if power is reaching the unit. Check your ground make sure it is tight and to bare metal.
Alignment adjustments
most newer model optical pickups take no manual focus/tracking adjustment.
I want tohook up a Kenwood KA-88 Amp. to a KT-58 Tuner to a DP-M5540 disc player and KA-68W Cassette deck. how do I do it?
Find the manuals or go by the basic INs to OUTs rule. REC = OUT, Play = IN. "Tuner" and "Aux/CD" are not literal. They're for anything BUT a turntable. But remember ONLY a turntable would ever use "PHONO".
This picture shows the rear of the KA-88
http://www.canuckaudiomart.com/view_images.php?cat=Amplifiers&catnick=amplifiers&cfid=168328&image_id=1469879
Register and download the CD manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-DP-M5540-CD-Players-manual/id/479ag101/t/2/
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
1helpful
Kenwood DP-MH5 CD Player won't open or play CDs and display reads err 08. Think a disc may have been loaded incorrectly. How can i fix it?
CDs can be removed but you must use great caution not to break or bend mechanism components. Its better to have unit serviced by pro/tech
Ok I had the kenwood KDC-MP235 installed and...
The front aux input is only capable of accepting audio signals and definitely won't display any track tags.
If you have an iPod, I think with the KCA-iP500 adapter it will display song info on the front as well as allow control from the Kenwood's controls.
As far as the song info on a CD - it should display if you've got a CD with CDTEXT info on it, or if you're playing an MP3/WMA CD. Most regular audio CDs won't be able to display song info.
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
