Dishwashers Logo
Question about Dishwashers
Defective door magnet on MiQ pass through dishwashser
Door switch signals different wash switch left 0 switch right 1 tank V Warning 403
Posted by Kieran Lynch on
1helpful
Where is the body control module located on a 2005 Chevy uplander?
Body Control Module (BCM)
Below the left side of the I/P to the left of the steering column.
Has three connectors.connector #1 52-Way F AMP Hybrid (BK) Body Control Module (BCM) C1 Pin
Wire Color
Circuit No.
Function
TN
860
Front Windshield Wiper Switch High Signal
WH
1459
Security System Sensor Supply Voltage
PK
1439
Ignition 1 Voltage
TN
28
Horn Relay Control
5
OG
300
Run Relay Control
6
TN
707
RAP Relay Coil Control
7
TN/WH
1969
Headlamp High Beam Relay Control
8
Not Used
9
PK/WH
1970
Headlamp Low Beam Relay Control
10
WH
1080
Park Lamp Relay Control
11
YE
749
Security Indicator Control
12
GY
91
Windshield Wiper Switch Signal 2
13
YE
196
Windshield Wiper Motor Park Switch Signal
14
TN
1835
Low Reference
15
L-GN/BK
1137
DRL Ambient Light Sensor Signal
16
YE
5066
Brake Pedal Position Sensor Signal
17
BK/WH
1651
Ground
18
Not Used
19
BK/WH
151
Ground
20
BK/WH
1651
Ground
21
YE
5
Crank Voltage
22
PK
1239
Ignition 1 Voltage
23
BN
1141
Accessory Voltage
24
Not Used
25
WH/BK
644
12-Volt Reference
26
PK/BK
109
Hood Ajar Switch Signal
27
OG
5688
10-Volt Reference
28
GY/BK
5689
Low Reference
29
BN/WH
230
Low Reference
30
PK
1444
I/P Dimming Control
31
OG/WH
812
I/P Dimming Voltage
32
Not Used
33
BN
5077
Low Reference
34
BN/WH
1571
Traction Control Switch Signal
35
GY/BK
1598
Courtesy Lamps Switch Off Signal
36
PK/BK
1597
Courtesy Lamps Switch On Signal
37
TN/WH
1455
Keyless Entry Signal
38
L-GN
1037
Class 2 Serial Data
39
L-GN
526
Stop Lamp Supply Voltage
40
L-GN
80
Key In Ignition Switch Signal
41
L-BU/WH
1314
Left Front Turn Signal Lamp Supply Voltage
42
D-BU/WH
1315
Right Front Turn Signal Lamp Supply Voltage
43
GY/BK
690
Courtesy Lamp High Control
44
OG
1732
Inadvertent Power Courtesy Lamp
45
Not Used
46
RD/WH
340
Battery Positive Voltage
47
OG
228
Windshield Washer Pump Control
48
GY
8
Instrument Panel Lamp Supply Voltage
49
D-GN/WH
1135
A/T Shift Lock Control Solenoid Control (w/o AQW)
GN/WH
1135
A/T Shift Lock Control Solenoid Control (AQW)
50
RD/WH
240
51
RD/WH
2440
52
RD/WH
1240
Connector #2 52-Way F Receptacle 0.64, 2.8 (BK) Release Tool/Test Probe: 12094429/J-35616-4A
Body Control Module (BCM) C2 Pin
Wire Color
Circuit No.
Function
Not Used
OG/BK
780
Driver Door Lock Switch Lock Signal
D-GN
5512
Liftgate Open Switch Signal
D-BU
245
Passenger Door Lock Switch Unlock Signal
5
L-GN/BK
748
Right Rear Door Ajar Switch Signal
6
YE/BK
1181
Right Rear Door Open Switch Signal
7
L-BU/BK
747
Left Rear Door Ajar Switch Signal
8
L-GN
1177
Right Front Door Open Switch Signal
9
L-BU
1134
Park Brake Switch Signal
10
L-BU
2380
Rear Parking Assist Chime Signal (UD7)
11
OG/BK
781
Driver Door Lock Switch Unlock Signal
12-15
Not Used
16
WH
193
Rear Defog Relay Control
17
TN/WH
746
Right Front Door Ajar Switch Signal
18
D-BU/WH
1179
Left Rear Door Open Switch Signal
19-21
Not Used
22
L-GN
1123
Door Lock Key Switch Lock Signal
23
WH
5075
Current Sensor Signal
24
PU
1124
Door Lock Key Switch Unlock Signal
25
TN
126
Left Front Door Open Switch Signal
26
GY/BK
745
Left Front Door Ajar Switch Signal
27-29
Not Used
30
WH
17
31
L-BU
244
Passenger Door Lock Switch Lock Signal
32-33
Not Used
34
PK/BK
1303
Liftgate Ajar Switch Signal (Early Production)
35
YE
2080
Low Reference
36
PK
2435
Low Reference
37
YE/BK
2079
Driver Heated Seat Cushion Temperature Sensor Signal
38
GY
2434
Passenger Heated Seat Cushion Temperature Sensor Signal
39
TN/WH
2430
Passenger Heated Seat Relay Control
40
PU
2477
Driver Heated Seat Relay Control
41
Not Used
42
L-GN
24
Backup Lamp Supply Voltage
43
YE
18
Left Rear Stop/Turn Lamp Supply Voltage
YE
18
44
GY
8
45
L-GN
275
Park/Neutral Position Park Signal (E58 w/o AQW)
L-GN
275
Park/Neutral Position Park Signal (E59 w/o AQW)
L-GN
275
Park/Neutral Position Park Signal (AQW)
46
TN
694
Driver Door Lock Actuator Unlock Control
47
Not Used
48
D-GN
19
Right Rear Stop/Turn Lamp Supply Voltage
D-GN
19
49
RD/WH
440
50
BK
550
Ground
51
TN
294
52
GY
295
Door Lock Actuator Lock Control
1helpful
Why my windows will not work nor the electric seats in my 2006 Cadillac STS. Where to check first ?
Check a wiring diagram an check power an ground for those systems . Also read factory service information on how they work . Electronic modules involved . DDM - driver door module . If this vehicle came to my shop , first thing I do , hook up factory scan tool an check input data from the door switch to the DDM . Check DTC'S - diagnostic trouble codes .
The power windows system consists of the following components:
• Driver door module (DDM) -- GMLAN device that receives and transmits messages and signals for window functionality
• Passenger front door module (PDM) -- GMLAN device that receives and transmits messages and signals for window functionality
• Left rear door module (LRDM) -- GMLAN device that receives and transmits messages and signals for window functionality
• Right rear door module (RRDM) -- GMLAN device that receives and transmits messages and signals for window functionality
• Driver door switch assembly (DDSA) -- GMLAN device that contains the driver, front passenger, RR and LR window and window lockout switches
• Right front power window switch -- provides switched ground window switch signals to the PDM for the front passenger window
• Left rear power window switch -- provides switched ground window switch signals to the LRDM for the left rear passenger window
• Right rear power window switch -- provides switched ground window switch signals to the RRDM for the right rear passenger window
• Left front power window motor -- contains position sensors and a module that receives signals from the DDM and provides a status signal to the DDM
• Right front power window motor -- contains position sensors and a module that receives signals from the PDM and provides a status signal to the PDM
• Left rear power window motor -- contains position sensors and a module that receives signals from the LRDM and provides a status signal to the LRDM
• Right rear power window motor -- contains position sensors and a module that receives signals from the RRDM and provides a status signal to the RRDM
• DRIVER DR MOD fuse (10-amp)
• FRT PASS DR MOD fuse (15-amp)
• REAR DR MOD fuse (10 amp)
• Power Window Motors Circuit Breaker (30-amp)
Your best bet , take it to a qualified repair shop.
How do we get a 2006 Uplander to stop chiming?
What is it chiming ? Chimes for different reasons , headlamps on , seat belt not buckled , etc.... What warning light is lit on the instrument cluster ? if any . seat belt , air bag's etc...
Audible Warnings Description and Operation
The audible warnings alert the driver of a system concern or a critical vehicle condition. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
Fasten Safety Belt Warning
The inflatable restraint sensing and diagnostic module (SDM) activates the fasten safety belt audible warning for 5-8 seconds. The fasten safety belt warning sounds and the fasten seat belt indicator illuminates when the following occurs:
• The ignition switch is in RUN, BULB TEST, or START position.
• The SDM detects that the driver's seat belt is not buckled (signal is low).
If the seat belt is buckled before the ignition is in RUN, BULB TEST, or START position, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops.
Key-In-Ignition Warning
The instrument panel cluster (IPC) activates the key-in-ignition audible warning. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is in OFF, LOCK, or ACCY position.
• The body control module (BCM) determines that the driver's door is open (signal is low).
• The BCM determines that the key-in-ignition switch is closed (signal is low).
Lights On Warning
The instrument panel cluster (IPC) activates the lights on audible warning. The lights on warning sounds when the following occurs:
• The key is not in the ignition.
• The body control module (BCM) determines that the drivers door is open (signal is low).
• The BCM determines that the headlamp switch is in the park or head position.
Rear Parking Assist
The rear object sensor control module activates the audible warning. The audible warning sounds whenever any of the indicators are illuminated on the rear parking assist display. For a description of the rear parking assist system refer to Object Detection Description and Operation.
Turn Signal Reminder
The instrument panel cluster (IPC) sounds the turn signal reminder once per each flash of the turn signal lamps when:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit (left or right turn).
• The vehicle has traveled a distance of 1.2 km (0.75 mi) by counting pulses on the vehicle speed input circuit.
The IPC turns off the turn signal reminder when either the ignition switch is turned to the LOCK position or to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits (left turn or right turn).
Additional Chimes
The following chimes will turn on when an associated indicator turns on in the instrument panel cluster (IPC):
• Low Fuel Indicator
• Low Oil Pressure Indicator
• OVER SPEED indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation.
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console.
Your have a problem with one of these systems , your best bet , take it to a qualified repair shop. They would do diagnostic's to find the problem .
Do any indicators illuminate when the chime sounds?
Go to Symptoms - Instrument Panel, Gages and Console
Go to Step 3
Turn the ignition OFF.
Remove the key from the ignition.
Turn the headlamp switch to OFF.
Close all of the vehicle doors.
Open one or more of the vehicle doors
Does the chime sound at all times regardless if the doors are open or closed?
Go to Step 15
Go to Step 4
With a scan tool, observe the LF Door Ajar Switch parameter and the RF Door Ajar Switch parameter in the instrument panel cluster BCM/Inputs data list.
Do all of the Door Ajar Switch parameters display Door Closed?
With a scan tool, observe the Left Rear Door Ajar Sw. parameter and the Right Rear Door Sw. parameter in the instrument panel cluster BCM/Inputs data list.
Do all of the Rear Door Switch parameters display Closed?
This is a 21 step diagnostic trouble shooting flow chart .
1helpful
My front loader LG won't spin or wash, what can I do?
(1) If the washer won't spin or agitate the door latch should be checked. The door latch can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design, if faulty replace.
(2) If the washer won't spin or agitate the rotor assembly at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
1helpful
I have a du code that will not go off and the door is locked.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
2answers
My maytag will not start it keeps beeping and the letter od keeps flashing
This is telling you it is getting a signal that the door is open.
If it is securely shut - the door latch, or switch is faulty.
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Error code du
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
57helpful
3answers
Ddo error - magnet goes where?
Ok, I am a little dense so I am posting a picture for others who have the same problem. Hope this helps. www.medlong.com
Top Dishwashers Experts
Marvin
Marvin
mark warfield
mark warfield
