Canon PC 1060 will not SCAN
Cleaning the rubber rollers on the ADF may help it to pull the paper through; I did it on my 1060 and I think it helped. (This was suggested in another post some time ago.)
Press Additional Functions. Use arrow keys to find ADJUST/CLEAN; press SET. Use arrow keys to find CLEAN ADF ROLLER. Open the ADF. Press SET. Each time you press SET, the rollers will rotate a partial turn. With the corner of a soft cloth slightly moistened with isopropyl (rubbing) alcohol, wipe the black rubber rollers both on the bottom and top of the ADF. Push SET again and rub again, several times. (DO NOT use alcohol on the long white roller! Use a dry cloth only, if you want to clean it.) Push STOP/RESET when you're done.
Touch the rollers only after they stop--not while they are rotating!
No guarantees, but it may be worth a try.
