I just get from a friend his Sony rear projection tv. I just plug in, it worked, but I have fine blue lines on the screen. When I switch to dvd, I got more lines but they appears thinner. Is this normal? If not, how do I fix this problem?
First try ajusting Blue screen control turn blue drive down, you have a focus/screen drive controlsfor all 3 tubes small square black box 3 on top are focus 3 on Bottom screen drive red/green/blue if this does not correct problem it means you might have a bad tube or something on blue CRT board that connects to tube.
Follow the steps below after verifying that the issue is occuring on other
channels and other video sources.
Turn off the television.
IMPORTANT: For a
projection television that uses an internal lamp, wait 5 minutes after turning
off the television to allow the lamp to cool before continuing with the
following steps.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
NOTE: If the television is
plugged into a power strip or surge protector, remove it from the power strip or
surge protector and plug it directly into the wall outlet. If the issue is
resolved, the problem is with the power strip or surge protector and not the
television.
Turn on the television.
If the issue is still unresolved, service may be required.
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Had this problem bout 2,3 years ago...it was fixed in about 5 minutes with the help of this article
Tonight I have to do this fix again..the blue lines came back about a week. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html I strongly urge you to save the web page locally on your hard drive or print it out and place with the tv manual....
Please pull front speaker grill and find focus block, fixed at corner having 6 control knobs on it. Find Blue Screen control knob there. Put your TV in AV mode to get dark screen and just press Display button on remote to have AV display. Now
slightly rotate control knobs counter clock wise until thin lines
(retrace) disappear. Job is done and put back speaker grill, press
display button again to disappear screen display.
Hello, You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun. If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further. thank you.
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error.
If you need more assistance please advice.
Arpi
