I HAVE KINDA SAME PROBLEM. When I to use it doesn't engaged. I have rock it back and forth to make work. Took repair 2 times, they blow the clutchs out air. Dust in the clutchs. It doesn't work for me. They can't get it not to work.
first of all unplug that freezer and wait for 15 mins. move it five feet from the wall. after 15mins, plug it back and kick in compressor at the same time!!!! remember plug and kick at the same time. the ckicking noise come from the starting relais. this says that the compressor has a problem. If it doesn't work ; you will have to call a service person who will replace the compressor for you.
Indicates a problem with the high voltage circuit. You could try unplugging the power cord, plug it back in and try again. If that doesn't work unplug the power cord again but leave unplugged for at least five hours and try again. Still doesn't work find a local repair shop that works on sony tvs and have them fix it for you.
unplug the unit for five minutes then try again. If it still doesn't work pick any button except pause/start and hold it down for 4 seconds off for four seconds...do that 4 times. The control will light up and go through a self diagnoses write down any codes that come up. Take the bottom panel off (three screws on the bottom) and you will find a tech sheet find the code that matches...hope this helps.
turn the igntion on, don't start, let it set for ten minutes Turn it off for 5 seconds then try to start it. If it lost memory for some reason and doesn't start . then do this three times , after the third time start it. that is the relearn procedure. Have a charger on it for the 30 minute relearn. Relearn is on for ten m off five s on ten off five on ten off five then start
keeping long time with battery in, this problem comes.
often remove the battery and put again, do several times like this, then you can see the camera working normally.
I think the reason it starts and turns off is most likely you fuel pump the abs light on could be the brake fluid level and or the brakes may need replaced.
