My Whirlpool American side by side refrigerator, the infra red sensor has stopped working on both sides of the ice maker side . s20drbb32-a/g the water works fine.
Open up the door ,hold in the bracket that is on the side(usually lrft side) and if the sensor light keeps blinking,it has to be replaced.HOpe this helps if so give us a 4 thumbs up. THANKS
yes ,,, i found quit a few to be bad ,,, if you have done all the other things thats all left ,,,, replace them and allow 24 hours for ice to drop / larry
the ice maker is of a poor design. There is a wheel that essentially is the mechanical timing device of the icemaker. The shaft in the wheel is of poor design and it breaks leaving a non-functioning useless ice maker. Whirlpool does not sell the wheel & shaft assembly - you have to virtually buy a new icemaker. Takes about 10 minutes to replace. Charge for the part = $107; charge for the labor = $175
the infa red sensor should be on constant if the switch on the right is in the on position, if the ben is enpty
if the ben is full the beam will flash interpting the ice maker from making ice untill the level of ice drops down below the holes in the bin then it will make ice again
beam part number if needed is4389102 it comes as a kit with the emitter and reciever boards
