Hi Purnachandra.
If you intend doing a repair job yourself you probably only need to contact the distributor of Samsung parts and ask for the individual parts by name.
You should also consider replacing the shaft which is attached to the inner drum. This can become damaged and will not give a good seal..
Try Googling your model number for a parts distributor in your area.
Good luck.
Nomess
Hi I just read your post. It sounds like you have got the shaft upside down. Large nut for the shaft goes on at bottom bearing & put your seal in last.Make sure you put enough grease on the lip of the seal.
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email: [email protected]
Bearings do exist but need a special puller to remove. If techs i n your
area have it part numbers are 22002934 , 22003441 also needed is
spacer 22002935 and seal kit 12002022 or else you need to order the
whole outer basket
The Rear Main Seal is the main area for an Oil Leak on the Transmission Side. You will need to drop the transmission to remove the old rear main seal and install the new one.
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
If you can estimate the labor rate in your are you should be able to get a good idea of the cost.
Parts Information
Part OEM Part Price Crankshaft Main Bearing Seal Rear Main Seal 12554314 $37.30
Crankshaft Main Bearing Seal Replace Rear Main Seal With Auto Trans 8.7 Hrs Note With Skid Plate, Add 0.4 hrs With Manual Trans Hydramatic MG5/MY2/M50 6.5 hrs New Venture MW2 5.2 hrs Note With Skid Plate, 0.4 hrs
