Refrigerators Logo
Question about Refrigerators
My defy G10715 ne was delivered yesterday and flashes E 15 , it does not cool or freeze
vince
  • Refrigerators Master
  • 1,716 Answers
In most cases powering it off for 5 min and back on clears the memory, so if the error code is not clearing or coming back this suggests the error is still present and you'll need to call for service.
Posted on Jan 22, 2023
Tom T
The E15 error code on a Defy G10715 appliance indicates a problem with the refrigerant system. This could be due to a leak in the system, a malfunctioning compressor, or a problem with the refrigerant pressure sensors.
In order to resolve the issue, you may need to contact a qualified technician for repair. Trying to fix the problem yourself could be dangerous and may also void the warranty on your appliance. The technician will be able to diagnose the specific cause of the E15 error code and provide a solution to get your appliance back up and running.
Posted on Jan 31, 2023
Why is my Defy F350 freezer not cold enough?
The flashing light is just warning you the freezer is no cold enough and a fault status exists.
Check that the cooling fins on the condenser are clear. Check the internal fan is working. It may need a top up of refrigerant gas.
https://www.google.com/search?q=Defy+F350+freezer
Dec 08, 2022 • Freezers
My defy fridge is not freezing
Perhaps this generic guide will help:
http://www.applianceoutletservice.com/troubleshooting-guide/freezer-not-freezing-refrigerator-section-cooling.htm
It is always helpful to know the model number of the applance.
I think your fridge is sold in South Africa but without the model number, there is unlikely to be much response.
My Defy refrigerator does not frees the freezes side error code 1 what is the problem?
link below says faulty temperature sensor
https://removeandreplace.com/2016/07/15/refrigerator-error-codes-all-major-fridge-brands-all-fault-codes/
manual below troubleshooting starts page 31
https://www.defy.co.za/wp-content/uploads/2016/06/3810190100-SBS-New-codes-A5.pdf
Some thing you can do if freezer not freezing below link
https://www.familyhandyman.com/appliance-repair/refrigerator-repair/fix-refrigerator-problems/
sometime is door is ajar not closed and sealing it will have to high a temperature.
Some issues which can cause higher temp. link below.
https://www.youtube.com/watch?v=45fPPzee364
Defy dff 401 Red exclamation "! "error is on..and the freezer side its freezing below and above its only cool not freezing .help me
Thermostat could be faulty ,i would be looking at that for a start ,but try turning it up to a higher setting.
Why do my double door defy fridge does not freeze it only keeps cool?
Probably low on freon or blockage in sealed system
Motorola defy unlock code
Hi visit prounlocking.com to unlock your Motorola Defy mobile from network lock .Here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
My thermostat is set on 72....but shows it is 76 in the house. I shut it off yesterday in case it was freezing up. 2 hours later, turned it back on and it cooled great the rest of the evening. I woke up...
it sounds as thought the coils on the unit need to be cleaned, make sure it is draining, if it still freezes up after cleaning coils and checking for draining then the unit has a leak and needs to fixed/charged. Hope this helps tim
New refrigerator does not cool
hi. thanks for the question. go back to costco .and get a new one .thanks the appliance doc
Open Questions:
0answers
Samsung RS2545SH Refrigerator. Please help me find the cause for RS2545SH compressor not staying on? For my RS2545SH the compressor starts for about 10 seconds and then seems to stop. I am wondering if there is an alternate way to reset the motherboard, from, say, directly on the motherboard? 1 I am able to see a 2-3 degrees F drop in the freezer evaporator coils during Power Freeze mode, but nothing better that small delta change. 2 Resetting the board Power Freeze + Power Cool for 10 seconds all appears normal. 3 The fuse on the motherboard has continuity. 4 Putting the appliance into Force Function mode FF FF, FO, rd, Fd and waiting 5-10 minutes does nothing to cause the compressor to come on for any extended period of time. 5 I have tested the resistance of the thermal sensors in the freezer and fresh food sections between 5.6k - 6.6k Ohms at different room temps., and over 13k Ohms when the sensor is placed in ice water. 6 A continuity test of the thermal fuses in both the freezer and fresh food sections shows both have continuity. 7 Both fans in the freezer and fresh food sections are spinning freely. 8 There is no ice build-up on either evaporator coils. 9 Error codes keep changing. Was initially 1, 4, 6, 8, 10, 13, and 14. Then was 2, 4, 6, 8, 10, 13, 14 when I changed thermal sensors out for new ones. This problem began when someone left the freezer door ajar for an extended period of time. The food at the top section of the freezer warmed, as the lower section remained frozen due to the ice build-up on the evaporator coils. The food in the fresh food section warmed. I am wondering if there is a better way to reset the motherboard... or what else I should be testing.
Top Refrigerators Experts
Marvin
Marvin
john h
