Car Audio & Video Logo
Question about AMP Car Audio & Video
Manual for volfenhag zx 7190
How can I connect this amp
Alex Urzica
    Novelist:
  • 59 Answers
The manual for the Volfenhag ZX 7190 amplifier will provide the specific instructions for connecting the amp to your system. Here are some general steps for connecting a car amplifier:
  1. Connect the power cable: Run the power cable from the battery to the amp, making sure that it is securely connected.
  2. Ground the amplifier: Connect the ground wire from the amp to a metal surface in the vehicle, such as a bolt on the chassis.
  3. Connect the RCA cables: Run the RCA cables from the head unit or source device to the amp, and connect them to the input jacks on the amp.
  4. Connect the speaker wires: Run the speaker wires from the amp to the speakers, making sure to match the positive and negative connections.
  5. Turn on the amp: Turn on the amp by switching the power switch to the on position.
It's important to make sure that the amplifier is properly connected to avoid damaging the amp or your vehicle's electrical system. Additionally, you should also refer to the manual for your specific Volfenhag ZX 7190 amplifier, as the connection process may vary based on the model and features.
Posted on Jan 29, 2023
Need help setting amp right
volfenhag's are cheap. you get what you pay for. that is the german equiv. to pyramid or kraco.
1helpful
I dont know if my amp is blown or not
Usually you will smell something weird if your amp is fried and it would make a pop noise.
But all amps are different. I say its time to be shopping for a new amp
2answers
I have a volfenhag zx-8400 and it just geos into protection mode
The most likely problem would be a blown fuse. I would replace all of the fuses.
I have a volfenhag zx-8400 amp. i dont have a manual. whats the proper way of conecting amp? its mounted on my speaker box, which is ported, 12' volfenhag 2500 watts. on the side of amp it had voltage...
The voltage prolly says like 100Mv-2v, it doesn't really matter, just know that that the lower you turn it the harder it bangs. The X-over depends on where your box is tuned, crank the knob down too about 40htz and you'll prolly be good, just don't turn it lower than your box's tuned frequency. And your rca's go to line input. And there shouldn't be a problem with mounting your amp vertically, you prolly just had a bad connection. Hope this helps if you have more questions please ask...
How to install a zx-hypercap in to my car
Hello youngbossrio,
Like other car audio capacitors, the Volfenhag zx-hypercap has two terminals, a positive and a negative. The negative terminal is connected to the metallic frame of the vehicle (ground). The positive terminal is connected "in-line" with the amp 12V positive terminal.
The capacitor should be as close as possible to the amp. Within a couple of feet is acceptable.
The capacitor needs to be "charged" before connecting it directly to 12V positive. This is done with a 1000 ohm resistor and a voltmeter. The exact value of the resistor is not critical but it should be in the 500-1000 ohm range. Use at least a 1 watt resistor (your capacitor may have come with a resistor for charging).
Hope this helps.
1helpful
Volfenhag ZX 7190, internals
They are actually "transistors" Part number 50N06! (50 Amps, 60 Volts N-CHANNEL POWER MOSFET). You can buy them Each for a couple dollars at your local radio shack!!!
Volfenhag ZX-7160 Car Audio Amplifier owners manual to adjust the frequency also wiring diagram [email protected]
its very easy to hook it up. your best bet is to join www.carstereo and ask your question there.but it is easy to set and hook up amp if you really need help email me
Top AMP Car Audio & Video Experts
leone C
leone C
Tom Chichester
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
