Computers & Internet Logo
Repair couldnt repair your pc
SSD not coming up
Posted by Oluwafemi Onia on
TECHNICAL SUPPORT
    Habit-Forming:
  • 67 Answers
Please share exact error.
Posted on Jan 22, 2023
1helpful
To get a harddrive upto 1TB with new bulk, what should pick?
Larry the Fixya Computer Guru says;
  • Anonymous Jan 19, 2021this question makes zero sense.
    No PC told, no telling if HDD is boot drive.
    no told OS you run, windows 10?
    we can not see over your shoulder and know what is in your had.
    tell what PC you have. first.
    gee, golly wise, man.
    then is this a 2nd drive to add or the boot drive now to be replaced
    1TB drives come in.
    SSD 2.5":
    SSD m.3
    2.5" HDd
    3.5" HDd.
    and more, sata and scsi and sas and FiberCh.
    and more.
    1TB tells me not a thing, even external drives.
    or if super lost post photo of your PC first.
    Do not buy a bulk
    it will fail.
    My PC boots from m.2
    and has 3 SSD and 1 HDD
    and external HDD.6TB
    and uSB stick,(boxes of them)
    and internal blueray drive, BD-r.
    what are you trying to do.? with what.
    tell what PC you have first.
    and why needed, PC dead, OS dead.
    or just need backup space.
    internal or external drives .what?
    the SSD 1TB is $100 can you afford that?
    ? if yes get that.
    forget HDD if not backing up 1000 movies.
SATA port 0 INTEL ssd locked
Please check the solution here:
1) Find or make an XP install with SATA set to IDE mode
2) Install .NET 2.0 & Intel SSD Toolbox
3) Shut down
4) Connect up your 'bricked' Intel SSD
5) Turn on system
6) Start Intel SSD Toolbox, and the SSD should now show up
7) Start another secure erase on it, and it should go through
8) Your Intel SSD is now unlocked again
http://forum.notebookreview.com/threads/how-to-resurrect-an-intel-ssd-locked-by-the-intel-ssd-toolbox.583269
You might also want to follow this Microsoft KB - You receive Stop 0x0000007B error after you move the Windows XP system...
And for some background info - https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
Hope that helps!
Peace
2answers
How do i install an ssd to replace hard drive
The drives will usually come with a utility to copy your old drive to the SSD and make the SSD the bootable drive. You just need to have both drives connected at the same time. Check for download instructions in the packaging with the drive or check the manufacturers website.
How to install ssd in asus s500ca
Am not an expert in this area. I have a different laptop. I swapped my HDD with ssd.
U just have to open up ur laptop.
Basically ssd can be mounted in three ways. Depends on how ur laptop hardware is arranged and what kind of ssd you install.
U can either mount ssd instead of current HDD, or swap ur optical drive with an ssd or even swap ur WiFi Bluetooth card with ssd. First open up ur laptop. Plenty of videos are available in YouTube, on how to dismantle it. Then choose what type of ssd and simply install it. All the best.
Front panel audio on pc seems to have a static noise when i put in headphones. Made sure The audio connector to the motherboard is in right. Any ideas?
are those high quality speakers with long cables?
possibly related to the cables being to long, coiled up, or close to other electrical equipment, couldnt say for sure.
not enough info
1helpful
How to Install ssd on G75
* Connect the SSD
* Put the Win7 disk in dvd drive
* Restart
* Boot from Win7 disk
* Install to SSD
* Copy files from HDD to SSD
* Profit
God bless you
How do I swap the HDD for an SSD
ssd is avaialble in different interfaces, you can buy whatever is suitable to you and replace with your old hard disk
4helpful
2answers
Please tell me if I can install this SSD drive in my Acer Aspire V3-771G laptop. What is the difference between SSD SATA II and III
A sata 3 SSD on a sata 2 PC will slow down slightly to sata 2 speeds, and vice versa. But this is usually acceptable since any current model SSD is much much faster than a normal hard drive so even installing a slower model SSD will be a big improvement. Its analogous to a porsche 911 and a volkswagen beetle. The 911 is faster than the beetle but both are much faster than horses.
your laptop has a normal hard drive. Most SSD's except apple SSD's are the same size and have the same connectors so 99% of the time it will work. you can see pictures of the SSD and compare it with your current hard drive
How to give ssid to my laptop
-please clarify. do you mean SSD?
-if yes, you can buy an SSD kit from known vendors like Western Digital of Segate or from any computer accessory retail store.
-you may need small philips head screw driver to open the hard drive compartment.
-NOTE: make sure that you are not voiding the hardware warranty of your laptop when you do this.
-choose the capacity that you need and it comes with instruction how to use the kit.
-normally what you will do is, you plug an external USB to SATA adapter onto the computer, plug the SSD on the other end. Install the software that comes with it, use the software to kinda clone the content of the built in drive to the SSD drive. After the clone process is done, you need to turn off the laptop, unplug the AC adapter, remove the battery pack, remove the hard drive that came with the laptop, put in the SSD, put back the battery pack, plug the AC adapter back in, then turn the computer on to test the SSD.
Marvin
Marvin
