Expert
- Posted on Jan 22, 2023
Re: When playing a DVD, my Bose 3-2-1 DVD player's...
- Make sure the video cables are properly connected. The cables that connect the DVD player to the TV should be securely plugged into the correct ports on each device. Double-check that the cables are not loose or damaged.
- Check the input source on your TV. Make sure the TV is set to the correct input source that the DVD player is connected to. For example, if the DVD player is connected to HDMI 1, then the TV should be set to HDMI 1 as well.
- Check the TV's settings. Some TVs have a "picture in picture" or "picture by picture" feature that may be turned on, preventing the main picture from showing.
- Check the DVD player's settings. Some DVD players have a setting that controls the aspect ratio of the picture. Make sure this is set correctly for your TV.
- Check the TV and DVD player compatibility. Some TV's are not compatible with older DVD players and this could be the reason for the lack of picture.
