Televison & Video Logo
PAT MURPHY Posted on Jan 20, 2023
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get to laser lens to clean t? - Televison & Video
Sandeep Mankar
Level 2:
Habit-Forming:
  • Expert 70 Answers
  • Posted on Jan 20, 2023
Sandeep Mankar
Expert
Level 2:
Habit-Forming:
Answers
70
Questions
0
Helped
12709
Points
266
It is recommended to use a lens cleaning disc, which can be found at most electronics stores. You can also use a soft, lint-free cloth slightly dampened with water or isopropyl alcohol. Be sure to avoid using abrasive materials or liquids, as they can damage the lens.
1helpful
2answers
How do you clean a laser on a DVD player
Clean the laser lens on a DVD player by following these steps:
  1. Turn off and unplug the player
  2. Find the laser lens and clean with a soft, lint-free cloth (no liquids/chemicals)
  3. Gently wipe lens in circular motion to remove dirt/dust
  4. Reassemble and plug in the player
  5. Test player to see if cleaning improved performance Note: Consider professional or manufacturer assistance if problem persists.
1helpful
Do i need a new laser or just clean the laser?
You can try cleaning the laser lens first. The lens can be cleaned with alcohol and qtips. If cleaning the lens doesn't work, then you may have a bad laser.
How do you use a NEXXTECH Laser Lens Cleaner?
The NexxTech Laser Lens Cleaner uses six super-soft brushes to ensure thorough and reliable cleaning, without harming the delicate optical components of your disks. Enjoy your DVDs more and improve your music archive by cleaning your optics in your CD or DVD ROM. The easy-to-use audio instructions walk you through the cleaning process from start to finish. This laser lens cleaner process will prolong the life of your disc player, improve visual clarity and sound quality. Features
  • Works on CD, DVD, Blu-ray - all optical drives
  • The six brush system cleans off the entire laser lens
  • Will not damage sensitive optical components
  • Includes easy-to-use audio instructions
How to Clean the Laser Pickup Lens on your DVD Player X missing_author_image.png eHow Electronics Editor This article was created by a professional writer and edited by experienced copy editors, both qualified members of the Demand Media Studios community. All articles go through an editorial process that includes subject matter guidelines, plagiarism review, fact-checking, and other steps in an effort to provide reliable information. By an eHow Contributor
Is your DVD player malfunctioning? If you're getting a no-disc error, you may need to clean the DVD player's laser pickup. The laser pickup is what reads DVD's and allows you to view them on your TV. If you need to clean the laser pickup lens on a DVD player, follow these simple steps.
Difficulty: Moderate Instructions things you'll need:
  • Isopropyl alcohol
  • DVD lens cleaner
    • 1 Make sure the laser pickup lens is actually the problem. There are a wide variety of reasons that a DVD player might not read a disc efficiently. The disc could be scratched or dirty, for example. Test the DVD player with a disc that you know works before trying to clean the lens.
    • 2 Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
    • 3 Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens.
    • 4 Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
    • 5 Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
    • 6 Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
Keeps repeating unknown disk
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Invalid disc error message
Take care.
Noread
Take care.
Disc error after loading
Take care.
1helpful
Dvds not playing at all or stopping after a few minutes
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it is stopping.
Good luck.
Mustek mp-85a works fine for period of time then stops and tries to re-load dvd. occurs in unpredictable time. have tried ac and battery only power, clean dvd, used previously working dvds, cleaned...
Good luck.
1helpful
Disc error
It is possible that there is some dirt on the laser lens. With great care the laser lens can be cleaned.
eHow, Clean Laser lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
If cleaning the laser lens does not fix it, there is the possibility that the laser unit and or its assembly, or the related electronics has a fault.
Jerry G.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
