Refrigerators Logo
Question about Samsung Refrigerators
Samsung refrigerator RF4287HARS panel shows error code 5 E, what is it and how can it be fixed?
Posted by Steven P Pietanze on
vince
  • Samsung Master
  • 1,548 Answers
The panel shows code 1 E and code 39 E can you tell me what is wrong the ice maker is not making ice
Both are Ice maker sensor errors, service required. I don't recommend you attempting repair without knowledge of appliance repair
Appliance 911 Sea Breeze
1helpful
4 year old Samsung fridge rf4287hars, flashing 22 e and 5 e codes after being unplugged for a short time. Unit isn't turning on...need help!
You need a new fan and defrost sensor on the side opposite your freezer that are the 2 codes present.
SAMSUNG REFRIGERATOR SHOWING CODE IE . POWER WENT OUT TODAY. HOW DO WE RESET IT?
Unplug the refrigerator for 5 minutes and plug it back. Now press "Energy Saver" and "Lighting" together and hold it for 3 seconds. It should clear the error message. Good luck!
2answers
What is error code of 23E on a samsung rf4287hars
My fridge got flooded for about 2 feet. But after the flood water was gone, I plugged the fridge and it was working. We moved out of the flooded home a year ago and I left the fridge (I deep cleaned the fridge of course) in a storage room for about a year. Now moved the unit to my garage and I was planning to use it as a backup fridge for some chemicals (not food related). However when I plugged it, it shows the error 23e and both fridge and freezer do not work. It is going to be an easy fix or should I let it go, considering the story?
Samsung RF4287HARS 5E error
5e indicates a failed fresh food defrost sensor. It should be repaired by a qualified Samsung technician. It is an inexpensive repair, but further damage could be caused while accessing the sensor. Make sure the tech installs the new sensor on the evaporator outlet, and not back on the inlet.
A samsung fridge RF4287HARS has error codes 40E, 21E and 22E
Hello Jerry Fuller,
All your codes point to the same circuit pack.
Main Control Board ...DA41-00884a
PCB "CN76" low voltage condition... Low Voltage condition
(PCB = Printed circuit board)
CALL...
If you have any questions or comments relating to Samsung products,
55 STANDISH COURT MISSISSAUGA,
ONTARIO L5R 4B2 CANADA
Please contact the SAMSUNG customer care center.
SAMSUNG ELECTRONICS CANADA, INC.
TEL : 905-542-3535 FAX : 905-542-3835
1-800-SAMSUNG (7267864)
www.samsung.com/ca
owners manual
Samsung RF4287HARS User Manual
Service MANUAL (CODES on page 60)
Samsung RF4287HARS Service Manual
Computer panel is not working and 1 E is flashing on the dark screen. The refrigerater and freezer are working.
Error is with your ice maker sensor. Unplug unit for 5 minutes and shut of your ice maker code should go away
1helpful
2answers
Samsung Refrigerator Error Code 1E or IE
1E error is bad freezer sensor. You would need to either replace PART NUMBER: DA32-10104N behind the freezer evaporator cover or the main pcb PART NUMBER: DA41-00684A
Error code OF OF
Try lighting and freezer for 3 seconds, or until you hear a beep. (The 2 left on my model) This worked both times I had the issue.
Top Samsung Refrigerators Experts
Marvin
Marvin
Steve
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
