Contributor
- Posted on Feb 18, 2023
Re: nordictrack elite 900 - Does not power on
Sorry to hear that your NordicTrack Elite 900 treadmill stopped working. Here are a few things you can do to troubleshoot the issue:
- Check the power source: Make sure the treadmill is plugged into a working electrical outlet and the power cord is securely connected to the treadmill.
- Check the circuit breaker: Locate the circuit breaker on the treadmill and make sure it hasn't tripped. If it has, reset it and see if the treadmill powers on.
- Check the safety key: If the safety key is not properly inserted or damaged, the treadmill will not power on. Make sure the safety key is securely in place and not damaged.
- Check the fuse: Some treadmills have a fuse on the power supply board or control board. You can check the owner's manual to see if your treadmill has a fuse and where it's located. If the fuse is blown, replace it with a new one of the same rating.
- Check the motor: If the motor is faulty, the treadmill will not power on. You can use a multimeter to test the continuity of the motor. If the motor is not working, you may need to replace it.
- Check the control board: If the control board is not working properly, the treadmill will not power on. You can test the control board with a multimeter to see if it's receiving power and sending signals to other components.
If you're not comfortable troubleshooting these issues on your own, it may be best to contact a professional technician or the manufacturer for assistance.
if u like to tip me https://paypal.me/AymanZiyat ty
