Question about Pioneer Audio Players & Recorders
Slow playing pioneer phonograph pl-202az
Posted by Christopher Fazekas on
wjha
    Habit-Forming:
    Scholar:
  • 115 Answers
Most record players use a rubber wheel against the turntable (on the inside) to turn it.. as they get old and brittle they tend to slip a lot. a temporary fix involves cleaning the rubber piece but it really needs replacing..
Posted on Jan 23, 2023
1helpful
Pioneer Pl990 turntable sounds awful.... I have a pioneer pl 990 record player connected to a pioneer amplifier and a sony CD player. when I play an LP, the sound is bass heavy and I can hardly hear t
When the turntable plays, do you get a howling bass heavy sound? Have you tried turning down the volume and bass? If that corrects the problem, you have what's known as Acoustic Feedback. Check to make sure the tonearm is properly set up first. If it is, please visit my website at Audioserviceclinic.com. You may contact me there. Thank you.
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
1helpful
The wire on the phono player PL-203AZ is not connecting to the receiver Pioneer SX312-R . I have wires to connect to Red and White from Phono to Receiver and another wire on Phono but the receiver do
I will need to know some things. Is the phone a part of the receiver?
does the phone have wires coming out of it?
What is the brand name of all the different components?
How old is the unit?
Does the phonograph have a needle in it?
Does the rest of the unit work like it should?
Thanks
Gary @ Fix Ya
Re. pioneer pl 990 turntable can the lid be closed
No you cannot play while lid is closed and YES you need an amp/receiver amp
1helpful
I have a Pioneer PL-202AZ turntable. I have to be able to plug it into my stereo receiver which is a Sony model # STR-DE635. What kind of adapter do I need? Any suggestions on where to purchase the...
I assume you mean the sony dosen't have a phono input? Then all you need is a Magnetic Cartridge Pre-amp. Your turntable plugs into this and the pre-amp goes into a spare aux on the Sony. Just do a search for the Pre-amp on google by putting in "Magnetic Cartridge Pre-amp".
Pioneer PL-12D TURNTABLE. Plays too fast.
Judging by your message I guess it's a secondhand machine, you have either been given or purchased. I suspect that someone might have played around with the speed preset to the motor. Take a look around the deck see if you can find it, sometimes there are two, one for each speed. They should correct it, unless something has gone.
Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
My turntable is playing a tad slow...it makes every record sound warped!
Hi CGS8021
Sounds like the belt is failing. You can get one from here
Where in the world are you? I will link you to the closest source.:)
regards
Robotek
Open Questions:
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Steve
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
