Tascam Midistudio 644 Logo
Question about Tascam Midistudio 644
No voltage on motor after replacing belt Tascam Midistudio 644
Hi, i replaced my belt on the midistudio. since the replacement the motor doesn't recieve any voltage. before the replacement it did. also the 3 I don't know what the're called voltage regulators on the side seem to get very hot. does anyone have any idea how to fix this? i've searched the internet over and over again. Kinds regards, Jake
Posted by Kurtius Cobainius on
Alex Urzica
    Novelist:
  • 59 Answers
The issue with the voltage regulators getting hot and the motor not receiving any voltage after replacing the belt on your midi studio could be caused by several factors. To resolve this issue, you can try the following steps:
  1. Check the wiring: Make sure that all wiring connections are secure and that no wires have been damaged or disconnected during the belt replacement.
  2. Check the voltage regulators: The voltage regulators could be overheating due to a short circuit or incorrect voltage. If they are hot to the touch, disconnect the power immediately and replace them with new ones if needed.
  3. Check the motor wiring: The motor may not be receiving voltage because of a wiring issue. Make sure that the motor's wiring is connected securely and that the voltage is present at the motor's terminals.
  4. Check the power supply: The power supply may not be providing enough voltage to power the motor and voltage regulators. Make sure the power supply is functioning properly and providing the correct voltage.
If these steps do not resolve the issue, you may need to seek further assistance from the manufacturer or a professional repair service. It is important to handle electronic components carefully and to follow all relevant safety guidelines to avoid damage or injury.
Posted on Jan 29, 2023
My freedom scooter 644 isn't getting power
wires that transmit the power within your device could need replacing as well. But before you do this, please make that you have checked the troubleshooting section of your vehicles manual. Thank you.
2answers
After serpentine belt broke turned engine off wont crank after replaced belt
look for damaged wires to the crank position sensor
run the fault codes
Voltage drops when blower motor is turned on
Check the internal fuse of the blower ...this not on the main fuse panel...if you look underneath if the blower unit you will find the card fuse...it may be shorting or have water or corrosion on the pcb circuitry.clean or replace...if this does not cure it seems you have a slipping fan belt on the alternator or the alternator is starting to fail.
1helpful
Winshield wiper delay intermitent module making noises
The wiper delay is in the steering column. It's a small box about 2 x 2 inches with a wiring harness attached. With the testing procedures I found below, you should be able to figure it out. I found wiper delays on eBay for around $10 to $20. Good luck.
WINDSHIELD WIPERS CHEROKEE, COMANCHE & WAGONEER 1. POWER INPUT Remove circuit breaker. Test battery side of circuit breaker. If battery voltage is not present, repair open to splice. Test across circuit breaker terminals. Tester reading should be zero (0) ohms. If not, replace circuit breaker. 2. GROUND Connector A unplugged. Test terminal G. Tester reading should be zero (0) ohms. If not, repair open to ground. 3. INTERMITTENT WIPERS Ignition switch in ACCY. Remove delay module and plug connectors together from the module. If wiper operate in LO and HI speed modes and mist (washer) is working, if wipers and mist operate, replace intermittent module. If not go to step 4. 4. WIPER/WASHER SWITCH Ignition in RUN, wiper switch position as indicated, back probe switch side of connector A for standard, connector B for intermittent: Test connector terminal E-wiper switch in LO and mist/intermittent. If battery voltage is not present, replace switch. test connector terminal C-wiper switch in HI. If battery voltage is not present, replace switch. Test connector terminal F-wiper switch to OFF. If battery voltage is present until wipers stop and then voltage drops to zero (0), system is working fine. If this does not occur, replace switch. 5. INTERMITTENT WIPERS Connector B unplug. Test across terminal A and D while rotating switch from minimum to maximum delay. If tester reading is not between 0-500 ohms, replace switch. Test across terminal A and G while rotating switch from minimum delay to maximum delay. If tester reading is between 0 and 500 ohms, replace wiper module. If not replace switch. 6. WIPER MOTOR Ignition in ACCY, wiper switch position as indicated, probe connector D. Test connector terminal 1. If resistance is no zero (0) ohms,repair open to ground. Test connector terminal 4-wiper switch in any position. If battery voltage is present, replace motor. if is not repair open from fuse panel. Test connector terminal 2-wiper switch in LO. If battery voltage is present, replace motor. If not , repair open from wiper switch. Test connector terminal 2-wiper switch in HI. If battery voltage is present, replace motor. If not , repair open from wiper switch. Test connector terminal 5-wiper switch OFF with voltmeter connected. If battery voltage is present until wipers stop and then voltage drops to zero, system is OK, replace motor. If not, repair open from wiper switch.
Found on the web. I hope this helps.
Rich Long
Heater blower motor doesn't run
check under your dash by the fuse box might be there
My heater/ac stopped blowing in the front, back still works
The front A/C and heater have a separete blower motor, so the front one should be checked for operation with battery voltage to it to see if it turns. If it doesn't turn when battery voltage is applied, then the motor is bad and should be replaced. Also, check for fuses blown or a bad relay.
I REPLACED THE BELTS ON MY 2004 TOYOTA AVALON. NOW MY POWER STEERING DOESN'T WORK. THE BELTS ARE TOYOTA EXACT REPLACEMENT AND THEY ARE ON CORRECT AND TIGHT. i MOVE THE PUMP AS FAR AS THE ADJUSMENT...
Hi, Your belt is put on incorrectly that is why the power steering doesn't work. Try to redo it.
We have looked for a diagram and no where to be seen. My advice is go get a manual. (Haynes)
Good luck.
--2005 GMC Envoy AC Trouble--(compressor still active) Have replaced blower motor (original one had "burn" evidence), resistor and resistor connector. The blower is still not working. Have...
SOUND LIKE BAD BLOWER MOTOR RESISTOR.CHECK BLOWER MOTOR HI BLOW FUSE AND RELAY.YOU WILL NEED OWNERS MANUAL IN GLOVE COMPARTMENT TO LOCATED BLOWER MOTOR FUSES AND RELAYS.
2helpful
Ok, I just got a new battery and coil ignition bwd.I also had my alternator re-built about 2 weeks ago,but my battery light still pops on when i turn the headlights on!my belts seem to be tight enuf. is it...
if you have a multi meter,
check voltage at battery with car running,should be at least 13-14 volts,
now turn on fan motor to high,flashers on,radio on, and check voltage at battery,regulator should have adjusted voltage to handle the load,should still be 13-14 volts,
now turn all that stuff off,and turn on headlights and recheck battery voltage,if below 13-14 volts replace regulator,if voltage is spiking higher than 14volts replace regulator.you do not need other belts.
Front washer motor
Washer Motor Can Have ALL the Voltage it needs Going to it but if it Does not GO THROUGH IT Its FAULTY, I would Replace motor as they DO Fail Often.
Top Tascam Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Tascam Car Audio and Video Expert? Answer questions, earn points and help others
