Sewing Machines Logo
Question about PfaFF Sewing Machines
How do you access the top of a Pfaff 1020 sewing machine?
The stitch selector knob will only switch between G and H and is stuck from G backward. Furthermore, those should both be zigzag stitches and one of them is a short straight stitch.
Posted by Patti Shanklin on
Sharifullah
    Habit-Forming:
  • 103 Answers
To access the top of a Pfaff 1020 sewing machine, you will need to remove the top cover by unscrewing the screws located on the back of the machine. Once the screws are removed, the top cover can be lifted off to access the internal components.
Posted on Jan 30, 2023
1helpful
Hello, I have a very old but wonderful Pfaff 260 automatic and the feed seems to be going backwards but is not pulling the fabric at all?
First, verify that the stitch length is set high enough that the feed dogs should be pulling the fabric to create a stitch.
If you have not recently oiled the machine, the feed dog mechanism may be stuck due to old oil that has solidified. Pick up some liquid Tri-Flow Synthetic Lube. While gently rocking the handwheel, apply a couple drops everywhere that metal rubs against metal. Do NOT oil rubber, leather, or synthetic parts!!! Don't forget to hit the spots under the sewing surface, ie the feed dogs, bobbin area, etc. Also, move the levers and selectors and hit those with a couple drops of oil. If things are still a bit sluggish, you can apply hot air from a handheld hairdryer at the interior of the machine. The heat will help loosen things.
P.S.--I picked up a frozen Pfaff 260 at the thrift store for $25. Used the above method to get things loose and now it sews beautifully!!!
2answers
Pfaff 360, how do I stop the zig zag stitch on my machine?
could you explain more about what the machine zig zag stitch is doing or not doing?
1helpful
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
1helpful
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
1helpful
My Elna SU will only do straight stitching it will not zig zag
My stitch selector keeps turning around and around
You will need to take the machine in for service.
I can't get my Pfaff 230a to straight stitch!
The stitch selector switch is most likely the culprit. Have you tried operating the machine upside down?
2helpful
Reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
