Sewing Machines Logo
Question about PfaFF Sewing Machines
Display shows battery on my pfaff anniversary edition
Posted by Louise on
Rick
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 41 Answers
For a 7550, this has been noted, AND also, if batteries show leak or any corrosion, clean only with mild soap, dish, do not use acetone, alcohol, any aggressive such as these can damage plated contacts.
How do I change the battery in my PFAFF 7550 creative sewing machine?
Switch on the sewing mahine to avoid deleting the memories during the battery change. Tilt the machine over backwards. A battery compartment is installed i the base. Using a screwdriver (as a lever, not to unscrew anything), pry up/off the cover. Take out the batteries. Insert new batteries with the "+" side facing upward. Replace the cover -- hinges should engage in the lower recess; the cover should snap in place. Use heavy duty batteries, such as Duracell. Battery size is AA
Posted on Jan 17, 2023
Pfaff expression 100th Anniversary
have it serviced as the needle timing may be out causing the needle to hit the bobbin hook
2answers
My Pfaff anniversary edition 1472 presser lever will not fully defend and leaves a gap above the material, it therefore does not sew correctly. I am quite handy. Can i fix this?
If you really are a "do-it-yourselfer" I would suggest getting a service manual for your machine (search the internet - try sewusa.com). The manual will describe what adjustments are available and how to get at them. Note that the covers on most machines are held by screws and hidden catches that have to be pried open.
1helpful
6answers
No display on my Pfaff Creative 1475 when plugged in light is on just no display? I changed batteries 2 double A on bottom of machine.
it's possible that some part of the computer is or has gone out, it would be a good idea to have the machine checked.
How do I change the battery in a Pfaff 1473 cd?
contact pfaff customer service and ask them where the hidden
battery is.
BATTERY WENT FLAT NOW SCREEN LIGHTS UP BUT THE DISPLAY IS BLANK ON PFAFF 7570 CREATIVE
it show a part of the problem says a battery went flat,,was there any corrosion in the place you put the battery. if there was corrision it could have shorted something in the machine
it's very posssible that something has gone wrong with the computer part of the machine
8helpful
I have a Pfaff Creative 1472 Anniversary Edition with a recurring problem. I cannot lower the presser bar completely to sit snugly on the fabric. I have to use my hands to push down on the machine foot to...
This is a very common problem with Pfaff machines. The presser system needs oil in the right places. If you are mechanically inclined I can give you step by step instructions how to repair it. An air compressor is very helpful.
No display
I have a Pfaff Expression which went the same way, but showed the error message "WD".
My dealer advised me to change the light bulb, which I've done, and since then its been fine.
Hope this works for your too.
All the best.
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
