Question about Canon Office Equipment & Supplies
Canon k10405 orange stays on plus can't switch off with on off button
My printer the orange light stays on and also I can switch off the printer with on off button have to pull plug to disconnect the mains
fa cosy
    Passionate:
    Visited the website for 10 consecutive days.
  • 113 Answers
If the orange light on your Canon K10405 printer is staying on and you cannot switch it off using the on/off button, there may be a few different causes.
  1. The printer may be in an error state and the light is indicating a problem with the printer. Check the printer's manual or the Canon website for troubleshooting steps specific to your printer.
  2. The power button may be faulty and not functioning properly. In this case, you may need to contact Canon technical support for assistance or take the printer to a professional repair technician
  3. It could be a problem with the power supply, in this case, the printer is not receiving the correct voltage, the power supply will need to be checked and replaced if necessary.
  4. If none of the above steps work, the problem may be with the main board, and the machine may need to be serviced by a professional technician.
It is not recommended to pull the plug as it can cause problems with the printer's firmware and might cause more damage, instead please try the steps above before requesting service.
Posted on Jan 17, 2023
Orange light on in service mode
Same thing here. Solid light stays on after trying to put into service mode.. did you get any solution before I dump this printer? Thanks
Canon Pixma MP160 doesn't print
Try doing a Reset.
Reset Printer Canon PIXMA MX310 or Canon MP160
  1. Leave the cartridges in the device.
  2. Turn off the printer using the on/off button.
  3. Keep the reset button pressed and press the on/off button now also. ...
  4. Release now the on/off button. ...
  5. Now open the printer and press the On / Off button. ...
  6. Now the printer with the on/off switch off button and turn on again.
More items...
Feb. 28, 2017
Reset Printer Canon PIXMA MX310 or Canon MP160 - Printer ...
9helpful
2answers
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
2answers
Ausbau von ink-absorber - canon pixma 4200ip
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
  2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
  6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
Canon Pixma iP4200, iP5200, iP6000, iP8500 Reset Procedure
  1. Turn off the Printers.
  2. Hold Resume button click POWER.
  3. Hold button RESUME, release POWER
  4. Then press the button again twice RESUME.
  5. Release all the buttons.
  6. Indicator led in green and stay green.
  7. Click the button 4 times RESUME, if you want to make another transaction.
1helpful
Canon i950 will not reset counter for waste tank full.....
For Canon i850, i950, S600
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
75helpful
2answers
Canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Open Questions:
Clive
Clive
old marine
old marine
