Argos electronic wine chiller 486/9292
If the orange light on your Canon K10405 printer is staying on and you cannot switch it off using the on/off button, there may be a few different causes.
It is not recommended to pull the plug as it can cause problems with the printer's firmware and might cause more damage, instead please try the steps above before requesting service.
My electronic wine cellar has a flashing error code e2
An E2 error code on an electronic wine cellar typically indicates a problem with the temperature sensor. This can happen if the sensor is malfunctioning, or if there is an issue with the wiring or connection between the sensor and the control board.
Here are a few steps you can try to troubleshoot the issue:
If none of the above steps resolve the issue, it may be necessary to contact the manufacturer or a professional technician for further assistance. Please refer to your manual or the manufacturer's website to see if they have a specific solution for the E2 error code on your wine cellar.
