Lands Phones Logo
Question about Lands Phones
My NEC-SL1000 all locals no dial tone and only blue steady solid light appears.what should be the problem
R SHOAIB
    Master:
  • 567 Answers
A steady blue light on your NEC-SL1000 system usually indicates that the system is in standby mode. However, the lack of a dial tone on all local lines indicates a problem with the system or phone lines. Here are a few steps you can try to troubleshoot the issue:
  1. Check the phone lines: Make sure that all phone lines connected to the system are properly connected and not damaged. If you have multiple lines, test each one individually to determine which line is causing the issue.
  2. Restart the system: Turn off the system and unplug it from the power source. Wait for at least 10 seconds before plugging it back in and turning it on again.
  3. Reset the system: If restarting the system doesn't work, you may need to perform a system reset. Refer to your user manual for specific instructions on how to reset your NEC-SL1000.
  4. Contact a professional: If none of the above steps work, you may need to contact a professional NEC-SL1000 technician to diagnose and fix the issue.
It's also possible that the steady blue light is indicating a different issue altogether. Again, refer to your user manual or contact a professional for further assistance.
Posted on Feb 26, 2023
2answers
Nec sl1000 call barring
How bar extensions from dialling out
3answers
HOW COULD I RESET THE NEC SL100 PBX SYSTEM?
Download manual from: https://www.manualslib.com/manual/832824/Nec-Sl1000.html?page=531
System Reset on Page No. 2-509 of the manual:
Dial 1 + press HOLD (Press Hold key only to cancel)
Factory reset sl1000
2answers
How to assign trunk lines on NEC SL1000 Keyphone System?
Try posting here:
http://www.tek-tips.com/threadminder.cfm?pid=937&page=1
3answers
MESSAGE LIGHT CONTINUES TO BLINK ON ALL HAND SETS (THERE ARE NO PENDING MSGS) WHEN I TRY TO DIAL OUT, (INSTEAD OD A STEADY DIAL TONE) I GET A RAPID BEEPING DIAL TONE) AFTER 7 TIMES, THEN IT BECOMES...
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
No dial tone on a nec dtu
The NEC phone is probably a business multi-line digital phone, requiring a phone 'back-end' system. Will not work on an analog 'home' phone line.
Top Lands Phones Experts
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
