BS69-18C939-AB
The Ford Figo 2010 2012 has 1 Diesel Engine and 1 Petrol Engine on offer. The Diesel engine is 1399 cc while the Petrol engine is 1196 cc . It is available with Manual transmission.Depending upon the variant and fuel type the Figo 2010 2012 has a mileage of 15.6 to 20.0 kmpl & Ground clearance of Figo 2010 2012 is 168mm. The Figo 2010 2012 is a 5 seater 4 cylinder car and has length of 3795mm, width of 1680mm and a wheelbase of 2489mm.
SOURCE: 2012 figo radio key code
The correct radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Removal Info here
www.fitaudio.com
Then post the radio make+model plus all the letters+numbers on any labels,barcodes and a 14 character Serial Number stamped in the metal casing.
This information can then be used to see if a code can be calculated
__________________________________________
www.ukbookshelf.co.uk
The correct radio SERIAL NUMBER is required for a Ford code
It usually begins with M or V followed by SIX digits ...such as M654321 or V654321
Sometimes pressing buttons 6 & 1 together or 6 & 2 will display this number
Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing
Radio removal instructions can be found here
www.fitaudio.com/index.php?CategoryID=13
www.radio-codes-webs.com
Are you sure you don't have a right hand thread, very common on Ford engines. Do you have at least a 400 Ft pound impact wrench?
SOURCE: I NEED A KEY CODE FOR THE BUILT IN RADIO IN A FORD FIGO 1.4 AMBIENTE 2012 MODEL
FOR A FORD FIGO THE KEY CODE IS PRINTED ON THE LEFT HAND SIDE OF THE GLOVE BOX, ITS A 4 DIGIT CODE WHICH CAN ALSO BE FOUND ON THE AUDIO MANUAL 1ST PAGE TOO... The keycode will be present in the sticker in the glove box.
