Televison & Video Logo
Question about Sony Televison & Video
Sony KDL-60-EX screen not lighting up, red light blinks 6 times, what could it be?
Screen won't light, flashing red light , 6 blinks Replaced T-con board. Still not working What else could it be? Please help me
Posted by craig miksis on
Larry
  • Sony Master
  • 4,809 Answers
I assume the full model number is KDL-60EX645. According to Sony service information the 6 blink code means inverter malfunction, this can be caused by 3 things, power board issues (inverter section), main board issues (missing BL_ON command) or failed backlights. On most brands backlight failure is common but not as much with Sony however I still think this may be the issue, I'd start by testing each of the inverter output lines, nominal voltage according to service info is 120 to 125 VDC per string, if you don't see the correct voltages, test from + side and use frame as ground, if you see voltage then the inverter is working and the over current or voltage is shutting down the inverter and backlights are bad. The backlight on command is 3.4 VDC, that could be tested as well but I don't think it's a main board issue.
Posted on Jan 16, 2023
abdulrahim ali
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Kindly check the power board if all voltages are there
Sony Bravia KDL-60EX500 no longer turns on.
Refer to Sony KDL 55EX500 Troubleshooting Manual Protection Mode Symptom...
5X Blink - TCON & HFR Failure
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board.
First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
see schematics in Sony KDL 55EX500 Troubleshooting Manual Page 23
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
2answers
When I turn on my sony KDL-52W5100, its acting like its booting up (showing the sony and bravia)then the screen goes blank. Then the red light start blinking 6 time. what do I do/
Hi
there is a back light problem the connectors of back light are loosing so please go to your nearest Sony service center & solve the problem but if you know about led so remove the o cell & clean the connectors but if you are end user please don't open the led because the panel is thin
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
1helpful
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
