Televison & Video Logo
Question about Panasonic Televison & Video
Can I get my stuck VHS tape out of my Panasonic VCR without disassembling it?
I had accidentally put in my VHS tape in my VCR and it won't come out. I've tried the Panasonic's FAQ on the topic but it wouldn't work when I tried it.
Posted by Darrell on
Kevin Cheney
    Problem Solver:
  • 7 Answers
Here are some steps you can try:
  1. Unplug the VCR and wait for it to cool down. A warm VCR can cause the tape to expand, making it harder to remove.
  2. Locate the cassette holder release button, which is typically located on the front or side of the VCR. Press the button to open the cassette holder.
  3. Gently pull the tape out of the VCR using your fingers. If the tape is stuck, try gently rocking it back and forth or wiggling it to loosen it.
  4. If the tape is still stuck, try using a pair of tweezers or a pencil to gently push the tape out of the VCR. Be careful not to damage the tape or the VCR.
  5. If the above methods do not work, you can try turning the VCR upside down and gently shaking it to try to loosen the tape.
  6. If none of the above methods work, you may have to disassemble the VCR to remove the tape. This should be done by a professional as it can cause damage to your equipment and void the warranty.
It's important to remember that attempting to forcefully remove a stuck tape can cause damage to both the tape and the VCR, so it's best to be patient and use gentle techniques.
Posted on Jan 15, 2023
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
I have a vhs video cassette stuck inside my vhs. Is their any way I can get it out without breaking the vcr. It is an older vcr, but I would like to get my tape out.
You might be able to unbolt the two halves of the VCR to remove the tape, but it depends on the VCR type and how it's stuck. You might end up having to get it serviced, or just getting a new VCR, as I can almost guarantee the tape is probably damaged beyond recovery, unfortunately.
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
2answers
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
VHS tape only partially goes in & then automatically ejects Panasonic PC-C1332W 13 in TV/VCR combo
sounds like there is a tape in it you are not aware of ,it may have one (vhs tape) stuck in it.
larry
Tape stuck in vhs players
Yes you can cut the tape, remove it and then go to radio shack or walmart electronics dept and get some special vhs repair tape.
2helpful
The cassette is stuck...
the tape is trapped in the mechanisms, you have to strip the VCR down to get the tape out
regards
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
