Kitchen Appliances - Others Logo
Question about Kitchen Appliances - Others
Russell Hobbs toaster 14356 anti tamper screwdriver
The handle at the side has come away and I would like to take the toaster apart to fix it but I notice that all along the bottom are anti tamper screw heads which are new to me and I would like to know how to remove them. They are not the normal torx heads it would need a tool with 6 prongs or indents to fit over the 6 small grooves in the side of the head.
Posted by Andrew Schofield on
john h
    Top Expert:
  • Kitchen Appl... Master
  • 28,861 Answers
Buy the security / anti-tamper bits at most tool or hardware stores
Posted on Jan 14, 2023
vince
  • 1,702 Answers
Here's a bunch from Amazon.....
https://www.amazon.com/anti-tamper-screwdriver/s?k=anti+tamper+screwdriver
Russell Hobbs toaster burns toast
It is a 'pop up toaster'. It should turn off the heat rather than 'reducing' it and pop up. The reviews mention the same. Time for a new one.
https://www.google.com/search?q=russell+hobbs+RHT302+burn+toast
New elements for Russell Hobbs Toaster 9276
go to an appliance repair shop and see it parts are available. go on the web--google-- russel hobbs toaster ---parts department and give your model number.
What Tool Do I Need To Open Russell Hobbs Glass Toaster
Take a look through these...
See if you can figure out which of the many
models are available... Pick ONE.
We could be helpful... If you let us...
Results 1 7 of 7
We can help... you WILL be proud.
Carnac the Magnificent
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
bought a new toaster I would like any account you have created for me to be deleted. thank you
3helpful
Require replacement wire which triggers the catch when the operating handle is pushed down. Where can I buy it?.
Russell Hobbs products are firmly placed at the budget end of the market and many of their products have little or no spares availability as they're often not designed to be repaired.
However, they do supply spares for some models if you're unable to fabricate the part yourself, see web address below:-
http://www.russell-hobbs.com/parts.shtml
I hope that you've found my answer to be useful and ask only that you return the favour by rating my answer.
How to take apart a Russell Hobbs 10617 Glass 2-Slice Toaster
You can access it from the side where the lever is, pull out the knob, remove the edge panel, remove the plastic cover and you will get to the lever and the electromagnet. Most likely the contacts have become dirty clean them up and also remove all bread crumbs from there
0-02-07-24db95e967e3a1b405ddc74bbf3d2d745d4e06787f02e8617d2636ca5249acc2_8e5c2626-undefined-undefined-0.jpg
0-02-07-77a87cfc40088664b7ecf814e7b3325eb6b75d19f8524f2d90f63c5d7418fd22_5652bc8d-undefined-undefined-1.jpg
0-02-07-a35b721c412be48dedee904b9d335950c41af1914c00e9cd306590962e70d01e_f4c5ef99-undefined-undefined-3.jpg
2answers
Russell Hobbs 10617 led bar
may have screws on the bottom and the loader knob usually has to be pried off. Place soft wood like a ruler against the housing and pry carefully from side to side with a large screwdriver. After working on it, plug it in outside to a ground-fault ac plug on a fireproof surface to test.
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
