Televison & Video Logo
Question about Sony Televison & Video
HOW DO I PROGRAM BRIVIAL SONY TV
Joliver C. Navida
To program a Sony TV, you will need to follow these steps:
  1. Press the "Menu" button on your remote control.
  2. Use the arrow buttons to navigate to the "Settings" menu, and then press the "Enter" button.
  3. Navigate to the "Installation" or "Setup" menu, and then press the "Enter" button.
  4. Select "Programming" or "Channel Setup," and then press the "Enter" button.
  5. Follow the on-screen instructions to scan for available channels. This will typically involve selecting your cable or antenna source and then initiating the scan.
  6. Once the scan is complete, use the arrow buttons to navigate through the list of channels and select the ones you wish to keep. Press the "Enter" button to lock them in.
  7. Exit the menu when you are finished.
Note that the specific steps may vary depending on the model and software version of your Sony TV. You may refer to the manual of the TV to get more information.
Posted on Jan 13, 2023
2answers
NEED CODE FOR TV
Tell me tv and universal remote model first
Program Sony rm-vz320 for smart tvs
You do not program the smart TV features in your remote, you use your remote to access and program those featurse on your TV via menus.
Sony bravia tv problems
Take the Sony remote-control and press SETUP.
Then, use the on-screen menu(s) to program the TV.
2helpful
Can i program sony flat screen tv with out remote
You might be able to program the channels, but you will need a remote for the time. Any Sony TV remote will work.
1helpful
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
What is the tv remote code for sony trinitron tv kv-9pt40
actually there is no set code for your model number. if you buy a sony remote is all you need. but if you bought a universal one than look in the manual and try all the codes for sony if that does not work then you have to program it manually. but go and buy a sony brand remote. all sony remotes work with all sony tv so you do not have to program it.
No manual; how can I program ode for my sony tv?
here is the manual,
http://www.fixya.com/support/p228950-sony_fd_trinitron_wega_kv_27fs100_27_tv/manual-16228
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
2answers
Cant program directtv remote to sony tv
See if this web sight helps in your problem
Good Luck and have a great day.
RCA Universal Remote Control-Programming Codes
Ed
NC Electronic
Mills, Wyoming
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
