Computers & Internet Logo
Question about Internet Computers & Internet
Error with Valcam - App Not Started
Hello - we have an issue it's believed to be a hardware issue w/ a Valcam 8500-630. We are calling the EXE from a browser and it causes Error - App Not Started to display. Is this a Valcam software / driver / hardware issue? If we use a virtual twain driver to test with, it works correctly in our software. How do you fix this error? Is it our Cabinet files that could be the cause? It's worked previously, and we can only get it to work in Internet Explorer...
Posted by JAY JENN on
Saurav Baid
Based on the information provided, it appears that the issue may be related to the Valcam 8500-630 hardware and its compatibility with the software or browser that you are using. The error message "App Not Started" suggests that there is a problem with starting the application or the software is not able to communicate with the hardware properly.
The fact that the issue only occurs when calling the EXE from a browser and that it works correctly when using a virtual twain driver with your software, suggests that the problem may be related to the browser or the settings of your software. To fix this error, you should first try to update the software and the drivers for the Valcam 8500-630 to the latest version. It is also important to check the compatibility of the software and browser you are using with the hardware.
It is also possible that the problem is related to your Cabinet files. If this is the case, you should try to replace the Cabinet files with a new set or check if the files are corrupted. As a last resort, you can try to reinstall the software and the drivers and check if that resolves the issue.
Posted on Jan 12, 2023
  • JAY JENN
    JAY JENN Jan 13, 2023
    After working on this for another 4 hours or so, we realized if we launch Internet Explorer as an ADMIN, then it can go out to C:\Windows\Syswow64 to open the Valcam EXE... is there a way to make it so IE can launch the program from a different directly instead of Syswow64?
Neoniq NQT-73GiQA. Why does it keep indicating 'Google play services has stopped'?
This is probably the most common error faced by Android users. This error is not critical and will not harm your android, it can be very annoying when the messages pop-ups continuously and says, "Unfortunately, Google Play Services has stopped working". So if your facing that error, and are unable to troubleshoot the problem, Here are your answers to the fix, and resolve your issue. So let's get started with all fixes to solve the error.
Reasons
Almost every kind of Playstore error occurs due to the Network issue, or any hardware or software issue. The main reason is Play Store is hard-wired with a specific device, and it may happen that accidentally Google has rolled out a wrong version of Google Play store in your device.
Before You Start
Before proceeding with the fixes, let's have a look at some short-tips that can help you in coming out from the issue as well, If any of the below-mentioned things happened with your device, so firstly perform these short-tricks. In most of the cases these short tricks solve the problem
  • If the app is crashing so frequently.
  • If the app isn't opening.
  • If the app doesn't respond.
  • If the app isn't working properly.
Try these small tricks, to fix the issues
  • Refresh networks.
  • Reboot your device.
  • Check application is updated.
  • Check for the Software or Android update.
  • In this case of Google Play Services, try uninstalling the updates.
Netflix app
Hello
If Netflix isn't working, you may be experiencing a network connectivity issue, an issue with your device, or an issue with your Netflix app or account. To get back to watching, first check if there is an error code or error message on-screen.
For any help or support just visit us: www Netflix Com Activate
(LOGITECHDESKTOPMESSENGER.EXE)
Hello marchits2002, please have a look in your Startup and disable the filename you stated above from running on startup.
To do this - Press Windows Key + R (to open the Run Dialog), then type MSCONFIG.EXE and press Enter.
You can now see the fourth tab called Startup, have a look at the list and uncheck any startup items you don't find necessary.
Apply the changes and restart computer. Done.
How do I start the webcam - does it have to be linked to a specific app, i.e. Skype, or can it be started independently? Thanks
Let me assist you in this regard.
This issue could be due to below reasons:
1. Corrupted Wireless drivers.
2. Corrupted BIOS.
3. Defective wireless adapter.
Before confirming, I request you to perform the below steps to isolate the issue.
Step 1: Update BIOS from the below softpaq:
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38173.exe
Installation Instructions
1. Download the SoftPaq .EXE file to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions.
Step 2: Uninstall and reinstall the wireless drivers as follows:
1. Click Start, Control Panel, Performance and Maintenance, and then System icon.
2. This opens the System properties window.
3. Select Hardware tab and click Device Manager.
4. Click "+" beside network tab.
5. Select the wlan and right click on it.
6. Click Uninstall and restart the Notebook.
Now reinstall the drivers from the below softpaq:
ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36542.exe
NOTE: After the files are unpacked, the Setup program runs automatically. If
the setup program (Setup.exe) needs to be run manually, look for it in the
download directory.
If the issue still persists, it could be due to defective wireless adapter. I suggest you to perform the below step to confirm the issue.
Remove and reseat wireless adapter:
To get the step by step instruction how to remove and reseat wireless adapter please go through the bellow URL:
http://h10032.www1.hp.com/ctg/Manual/c01095493.pdf
Please refer page number:35 and 36 (44 of 122)
Please let me know if the issue still persist or you have any other issue because it is important that I resolve your issue in a timely manner. I would like to add that we value your precious time and We assure you of our dedicated support, 24 hours, 365 days a year.
1helpful
Firefox.exe error signature when attempt to play videos
Hello truenobility,
You should re-install the FireFox App and Setup the Adope Flash Player , you can get it over Here , then everything gonna be okay
Thank you for using FixYa.
3helpful
Nokia 500 gps. Display freezes and has a box in upper right corner. Bluetooth hands free works but navigation does not. Troubleshooting info found on Nokia Wiki says "this means the shell is started...
Try this, I have similar issue with the unit freezes and has a box in upper right corner. Go to the Nokia website, download their software update wizard and follow the instruction. It will flash the unit and fix the issue.
When starting the computer(HP Pavillion 860)I get the message:"Runner Error:Logitech Desktop Messenger.exe.lacks a "-"(the app.id.seperator).What to [email protected]
Start, Run, MSCONFIG, the on the startup tab find the app that matches this and uncheck it, apply changes and rebbotm should clear up the issue.
2answers
Legacy
Please try the following:
Click Start >> Run >>
Type the follow command in the Open box.
"net.exe stop wuauserv" (w/o quotes)
Press Ok
Repeat the same for the following commands:
regsvr32.exe wuapi.dll
regsvr32.exe wups.dll
regsvr32.exe wuaueng.dll
regsvr32.exe wucltui.dll
regsvr32.exe MSXML3.dll
regsvr32.exe qmgr.dll
regsvr32.exe qmgrprxy.dll
net.exe start wuauserv
Restart the machine and try again.
Open Questions:
Steve Nordquist
Steve Nordquist
 Grubhead
Grubhead
NOEL
NOEL
