Expert
- Posted on Jan 12, 2023
Re: Hp color laserjet 4700 printing with shadows
If your HP Color LaserJet 4700 is printing with shadows, it could be caused by a few different issues. Here are a few potential causes:
- Toner Cartridges: The toner cartridges may be low or empty, causing the shadows to appear. It is recommended to check the toner levels and replace the cartridges if necessary.
- Toner Smears: The toner smears on the drum or the fuser can cause shadows to appear on the printouts. Clean the drum and fuser with a lint-free cloth and check if the problem persists.
- Fuser Unit: The fuser unit could be malfunctioning and may need to be replaced.
- Paper Quality: Using low-quality or damp paper can cause shadows to appear on the printouts. Use high-quality, dry paper for better results.
- Printer settings: Some printer settings can also cause shadows to appear, such as toner density or print resolution. Ensure that the settings are set to the recommended level.
- Dust or debris: Dust or debris inside the printer can cause shadows, Clean the inside of the printer and check if the problem persists.
It is important to diagnose the specific cause of the problem before attempting to fix it. If you are not comfortable with troubleshooting the problem, it is best to contact HP support or a qualified technician for assistance.
Testimonial: "Solved the problem by re sitting the scanners"
