When I hit a small bump in the road, my DEH-1700 frequently develops lots of static but when I push in on the upper right corner of face plate, static typically goes away
don't hit any more bumps. The problem could be in several areas. I'm going to say that you may have a loose capacitor inside If I had the radio here I could fix it but because the problem may be so spread it could be a lot of things Are you a truck driver? If you are take it to a CB shop at one of the many truck stops and see if they can fix it for you .
It sounds like you may have a cracked display board. Have you dropped the face plate or has anything hit it while driving? If this is the case, you will need to take it in for repair, but since it is a low cost radio it may not be worth spending that kind of money on it. If the display board is not cracked, it could be the microprocessor or another electronic device. It does not sound like the type of repair that would be able to be done without having a technician check it out. As with most types of problems with electronic equipment, the cause of the problem can be a variety of different things that can only be determined with certainty by troubleshooting by a technician. Since you have no control functions from the display, the most common cause of this I have seen is the board being cracked. It only takes a very small crack in just the right place to render it inoperative.
I am sorry to give you such bad news, if I thought that it was something simple I would tell you. But this is not a simple problem that can be solved without checking it out on a repair bench with the proper test equipment.
If you can find a service center that offers free estimates it would be worth getting it checked out, but if I were you, I would buy a new one and then you would at least have the 1 year manufacturers warranty for about the same price or maybe even cheaper than getting it repaired.
Another option for you could be to contact Pioneer customer service and see if they may cover it for you if your warranty has already expired.
I hope this helped, let me know if I can be of any further help.
since you have a jeep thinking you go off road maybe hit couple bumps and jared something loose in the back of sterio system this is what i would check first
after that it might be that the sterio's face plate is not makeing connection right to base sterio
