Question about Yamaha Audio Players & Recorders
I have a Yamaha RX-V681. It went into protection mode.
Followed directions from past posts to get out of protection mode. Hold tone/ straight buttons then power. But no action. Only light next to power button. Happened after power outage. This is receiver toast?
Posted by Ken Wilkes on
R SHOAIB
    Master:
  • 567 Answers
If your Yamaha RX-V681 is not responding after following the steps to exit protection mode, it is possible that there is a more serious issue with the unit. It is recommended to unplug the unit and let it sit for a few minutes before attempting the procedure again. If this does not work, it may be necessary to have the unit serviced by a professional technician or contact Yamaha customer support for further assistance.
Posted on Feb 25, 2023
1helpful
My RX- V673 Yamaha receiver won't turn on. I have power and the stand by switch is on
Try holding the 'tone control' and 'info' buttons and press power. This will unlock it if it is protect mode. If it turns back off right away, then you most likely have a problem in the amp circuit which needs to be repaired.
2answers
Hi;my Yamaha receiver RX-V 373 will not turn on. No power. No display. It may be that the unit went into protection mode. Can anyone there, help me, restart my unit back to factory condition?
If you have power it should click before protection mode and have a light showing it's in protection mode.
After the transformer there's some resistors that have failed if it's in protection mode normally it's one or two that have failed, you can get the reading of what they should be by testing them
1helpful
My receiver just shut off while watching a movie and won't turn back on. I checked the only fuse i could find. Where to go from here.
Press and hold the "straight" and "Tone control" buttons and press power. This should release the protect lock that the receiver is in. If it shuts back off immediately, then you most likely have a blown amp that will need to be repaired.
My Yamaha RX-V663 Receiver doesnt turn on. After the power at my house went off, it doesnt turn on anymore. How do i fix it?
Try holding the "straight" and "audio select" buttons and press power. this may return power if the unit is locked in protect.
Yamaha RV-X663 not powering up.....
it is probably in protect mode. Try holding the 'straight' and 'audio select' buttons and pressing power. See what happens.
3helpful
Yamaha Receiver won't turn on after USB plugin in. Help!
Unit is in protect mode. Sometimes an ipod draws too much current through the usb jack and causes the unit to shut down due to an abnormal voltage being detectected. Press and hold the 'info' and 'tone control' buttons and push power. This should turn the unit on. Turn it back off and turn it on again and should power up normally. If the ipod continues to make the unit shut down when plugged in, try and make sure it is fully charged before plugging it into the receiver - this may help.
3helpful
2answers
Htr-3064 reset power on
I had a Power surge in Brisbane this week and found my YAMAHA HTR-3064 AV receiver unresponsive. Thanks to the Squish22's post, I tried the above approach, which is also listed for another Yamaha model (RX-V667) Unfortunately nothing happened. Another post suggested holding the 'straight' button as you power up to go into "advanced" menu (under DILLIGAF's post.) This also did not work.
I thought I'd try pressing all 3 buttons and powering up, which worked a treat. so here's exactly what I did:
Yamaha HTR-3064 - Protection mode reset:
  1. Remove the Power cord form mains power and wait 10 seconds.
  2. Plug cord in and turn on wall socket power.
  3. While holding down "info", "straight" and "tone control" buttons, press "main zone" power button. I got a click and it was good to go from there.
I had all of my speakers unplugged at the time and tested off the headphone jack before plugging all the cables back in again. Not sure if I needed to unplug everything, but I was about to dismantle and look for a fuse when I tried this method.
Saved me a new system / service fee. Hope it helps you too.
Thanks Squish22 and DILLIGAF for the head-start!
4helpful
How do I reset my yamaha rx-v671 receiver?
If there is no apparent cause for the protection mode activating (such as shorted speakers, burning smell, blown fuses, lighting strike or mains power surges), reset the protection as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Any idea what firmware the yamaha RXV465 is supplied with at new??
CHECK UPDATED VERSION Press and hold the [STRAIGHT] button on the front panel and keep it pressed while you press the [STANDBY/ON] button. Once the front panel displays "Advance Setup", release the [STRAIGHT] button. Then, press and hold the [TONE CONTROL] button for about 3 seconds until front panel displays “M:K032 8FFD”.
K032: version of firmware 8FFD: checksum
Open Questions:
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
