Televison & Video Logo
Question about Sony Televison & Video
Best way to connect sony Bravia TV, RDR-HXD890 recorder and Sky Q box, please??
I just had the Sky Q box and the TV, but dug out my old RDR-HXD890 player/recorder and wanted to connect that too. But how best to do so, please?? As in, what goes where!
Posted by Sally Scott on
Ian Njogu
    Sergeant:
  • 165 Answers
Connecting your old RDR-HXD890 player/recorder to your Sky Q box and TV can be done by using the appropriate cables and connections. Here is an example of how you can connect the devices:
  1. Connect the HDMI output of the Sky Q box to the HDMI input of the RDR-HXD890 using an HDMI cable. This will send the video and audio signals from the Sky Q box to the RDR-HXD890.
  2. Connect the HDMI output of the RDR-HXD890 to the HDMI input of the TV using an HDMI cable. This will send the video and audio signals from the RDR-HXD890 to the TV.
  3. Connect the aerial cable to the aerial input of the RDR-HXD890
  4. Connect the RDR-HXD890 to the power outlet
  5. Turn on all the devices and set the TV to the HDMI input where the RDR-HXD890 is connected.
By connecting your devices in this manner, you will be able to watch and record TV shows and movies from your Sky Q box through the RDR-HXD890 and display them on your TV.
Posted on Jan 13, 2023
Testimonial: "Thank you - but I don't want to record from the SkyQ box, just be able to play DVDs and record from TV. But thank you anyway."
Can not record or playback on sony rdr hxd 890 Help please from a repairer. rdr hxd 890
http://www.sony.co.uk/support/en/product/RDR-HXD890/downloads/FW_DVDR_124 Make sure the ribbon cable going to the laser head from the main board is seated correctly at both ends. Use a scope to verify signals present at the input to the laser. If not then find where it stops on the main board. If it is present then replace the laser mechanism.
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Cannot remove caption
Check your menus for removal of this notice. It is there just a PIA to find it!
2helpful
Press the info button once on the HXD890's remote control (button top right on the main circle in the middle). All should then dissappear.
Sony DVD RDR-HX650 - set up
Sony UK has info how to hook up this unit. Please check there.
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
