Car Audio & Video Logo
Question about Car Audio & Video
BEOSOUND9000 - When BEO4 is set to 'CD' 'Shift 90258' for test mode, when I then press '72' the message on the BEOSOUND 9000MkIII states 'Wrong SRC/TM' even though It worked at the start of the repair
Posted by Barry Hughes on
Alex Urzica
    Novelist:
  • 59 Answers
The message "Wrong SRC/TM" on a BEOSOUND 9000MkIII when pressing '72' while in test mode (Shift 90258) and set to 'CD' could indicate that there is an issue with the source selection or the test mode itself. To resolve this issue, you can try the following steps:
  1. Check the source selection: Make sure that the correct source (CD) is selected on the BEO4 and that it is functioning properly.
  2. Check the test mode: Verify that the test mode has been activated correctly and that the Shift 90258 code has been entered correctly.
  3. Check for firmware updates: Make sure that the firmware on the BEOSOUND 9000MkIII is up-to-date. If there is a firmware update available, install it to resolve any issues with the test mode.
  4. Factory reset: If the above steps do not resolve the issue, a factory reset of the BEOSOUND 9000MkIII may be necessary. This will restore the unit to its original settings and resolve any software-related issues.
If these steps do not resolve the issue, you may need to seek further assistance from the manufacturer or a professional repair service. It's important to follow the manufacturer's instructions and safety guidelines when attempting to repair or troubleshoot your system to avoid damaging the unit or causing potential harm.
Posted on Jan 29, 2023
BEOSOUND 5 RESET
To do a BeoSound 5 Encore factory reset:
  1. Go to 'mode' > 'settings', but do not press <go>.
  2. Now press <arrow right> two times and then press <go>. This opens the service menu in English.
  3. Look for the option to "reset to factory defaults" under the "Maintenance" menu and press <go>.
I have a multipass 730
Reset Waste Ink Canon MPC190
1) Enter SERVICE MODE.---
By pressing Menu Copy Scan Copy Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
All the best
1helpful
Bang and olufsen beosound 3000 does not read cd and loading stops. Can you help? Thanks
I never had like that. But "normally" there may be two reasons: CD fault or control board fault. Sometime main control keeps memorized wrong data and (in my Ouverture) CD unit simply is not responding and not loading - standing still. No way to move on except plugging off the power, press CD start on remote with no power, plug in power and try again. It clears bad data. I suspect it happened few times when I stopped CD player by remote or local main switch off.
"wrong cartridge" message appears, new
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
I found a reset sequence for a MP730 printer in this website that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
By pressing Menu-Copy-#
6) Press the [OK] key.
Skip step (6) since there is no [OK] key on F30 or F50 printers.
Having problem linking my beo4 remote to my b&o beosound 9000. As soon as I connect other units to my 9000 like ny tv or ipod , i loose control of the remote operation right away
hi is your bs9000 connected to a b&o speaker? if not, ir wont work. b&o speaker wire or power link triggers the sensor once it is plugged to the bs9000. hope this help
I am getting a message traveling across my screen that says, "Input Signal Out of Range." Then, after about 1 minute I get a "going to Sleep" message, and the screen goes into sleep mode. I keep having to...
that message means, you have the unstated PC, set to a super high resolution, that is totally ******* on this old screen,
buy a newer screen,
or change the resolution.
no PC stated , at all. model , is it HP?
no OS stated, if XP hit F8 and run safe mode and lower the resolution to 1024x768.
only these work,,never higher.
1024 x 768 / 60 Hz
1024 x 768 / 70 Hz
1024 x 768 / 75 Hz
800 x 600 / 60 Hz
800 x 600 / 72 Hz
800 x 600 / 75 Hz
640 x 480 / 60 Hz
640 x 480 / 72 Hz
640 x 480 / 75 Hz
832 x 624 / 75 Hz
720 x 400 / 70 Hz
Remote code for power on/off for Beosound 1
use the manual off switch on the product or use a beolink 1000 or beo4.
Will the printer become damaged because repeated error message?
Do a EEPROM initialization:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My Cannon Pixma MP110 printer is showing message;- The Waste absorber is full. What can I do to fix this?
Try this
Reset Waste Ink
By pressing Menu, Copy, Scan, Copy, Copy
2answers
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
