Televison & Video Logo
Question about Panasonic Televison & Video
Panasonic Viera 50 plasma tv, model TH-50PX60U, no picture, no sound and power light flashes 10 times, off 2 seconds, then repeats the cycle.
I have a Panasonic Viera 50 plasma tv, model TH-50PX60U, purchased in 2006. The TV has worked flawlessly since purchased, but just recently stopped working, i.e., no picture and no sound, when powered on and the red power on light flashes ten times, then goes dark for two seconds and then repeats that pattern instead of remaining on without interruption. The Operating Manual does not provide a clue as to what the flashing power light means or otherwise provide any assistance with diagnosing the issue. Seeking any information as to what the flashing power light signifies or other troubleshooting insights to diagnose the problem with the TV. Thank you in advance for any and all assistance with this problem.
Larry
  • Panasonic Master
  • 4,809 Answers
DO NOT change the main board unless you want to waste some money as it will not fix the set, I've seen this issue you have many times, this flash code means P board issues. In almost every case it's been bad caps, there will be 3 larger caps on the sustain or P board, they will have a slight bulge to them and be defective, new ones can be ordered from digikey and soldered in or you can change the board if you can find one.
Posted on Jan 17, 2023
Testimonial: "Thank you, Larry."
abdulrahim ali
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Mostly 10 blinks on panasonic means main board is faulty, you need to replace it
Posted on Jan 16, 2023
Testimonial: "Thank you!"
  • Larry Jan 16, 2023
    This will not be a main board issue, see my post for some help
  • abdulrahim ali Jan 17, 2023
    Well noted
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
3helpful
When the Panasonic TH-50PX60U is turned on, the button beside the power switch flashes 10 times, stops and repeats the flashing. The tv will not actually turn on.
10 times red light blinking shows problem with PA board and/or H board, both boards are available in shopjimmy.com for $35 and $45
Replace required board to solve this issue.
Hope this info will help you.
Thanks.
6helpful
My set wont come on.
The tv power supply board is dead.That the board where,the power a/c cord plug into it.That the power supply board.Tries websites like Shopjimmy.com Ebay.com to buy a whole refurbish power supply board for the replacement.
10helpful
2answers
Panasonic Viera TH-50PX60U Plasma is stuck on one channel. Only the power function works on the remote and only the On/Off function works on the TV. Any ideas??
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace. For further questions, please add your comment.
4helpful
Error codes. no picture or sound after turning
When the SUB5V or MAIN9V/SUB9V, short or over-voltage 15V short condition occurs, the TV shuts down and the power LED blinks 10 times.
10helpful
4answers
Panasonic th-50px60u power indicator is blinking 10 times
There are two guides, one for 10 blinks at power on:
or, 10 blinks at plug in:
1helpful
4helpful
2answers
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
