Cameras Logo
Question about Canon Cameras
Canon powershot sd 750 not turning on after few years of no use
I recently bought a used canon powershot sd 750 from ebay and am unable to turn it on. the seller indicated that the battery had been dead since 2019 so he had not used it since then, but it was in good working condition once the battery gets charged. i bought my own charger and charged the battery but the camera still does not turn on, anyone have advice? should i just try charging it for longer? should i buy a new battery? does it matter that the battery has not been charged since 2019? let me know!
Simon Atkinson
  • Canon Master
  • 3,383 Answers
Simplest answer is to replace the battery. If it hasn't been used or charged for so long the battery will be considered 'Old' so it will not hold charge. I think the higher quality brand name batteries for it are usually a reasonable price and not expensive.
Posted on Jan 08, 2023
20helpful
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
tip
I have the same problem with a Canon Powershot s20. Bought approx 5 years ago...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
3helpful
2answers
Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
Memory card error
I assume that you know that there is a tiny tiny on-off switch on the edge of each SD card. If they are locked in the off position....
11helpful
Dropped my Canon SD 750 and it won't turn on
KEN,
I HAVE LOCATED THREE REPAIR SHOPS THAT WORK ON CANON AND GIVE FREE QUOTES. I DO NOT ENDORSE ANY OF THESE, BUT PASS THEM ON FOR YOUR INFORMATION. AS FAR AS I KNOW THEY ARE RESPONSIBLE. THE WEBSITES ARE BELOW. I HOPE THIS HELPS! GOOD LUCK! IF YOU NEED ADDITIONAL HELP,REPLY TO:ARCLIGHT1217
www.digitechcamerarepair.com
www.PrecisionCamera.com
www.keh.com
Sd 750 does not turn on with batt fully charged
i have the same problem please let me know how you make out
Memory Card Error
Check in the Manual that the camera can accept 2Gb.
If it say it can then return the card for replacement.
Canon powershot sd 750 problems
Check on the CD software you received with your camera whether it support the Win Xp OS. In case it doesn't support your OS, go to the Canon web site and download to your PC the relevant drivers for your camera and OS. Good luck !
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
