Question about Yamaha Audio Players & Recorders
Rx-v565 code RAV293 Yamaha remote
What are the codes to the remote are AV 293 for receiver rxv565 thank you
Devin
    Scholar:
    New Friend:
  • 49 Answers
The codes for the AV 293 remote to operate a Yamaha RXV565 receiver may vary depending on the specific model of the remote. Here are a few steps you can follow to program the AV 293 remote to work with your Yamaha RXV565 receiver:
  1. Turn on the Yamaha RXV565 receiver.
  2. Press and hold the "Power" and "Input" buttons on the AV 293 remote simultaneously until the red LED light flashes twice.
  3. Press the "Power" button on the AV 293 remote.
  4. Enter the three-digit code for your Yamaha RXV565 receiver using the number buttons on the remote. The code may be listed in the instruction manual for the AV 293 remote or you can try one of the following codes: 431, 439, 471, 478, 559, or 678.
  5. Press the "Input" button on the AV 293 remote to test the code. If the code is correct, the Yamaha RXV565 receiver should turn off. If the code is incorrect, the red LED light on the AV 293 remote will flash twice.
  6. Repeat the above steps to try a different code if necessary.
If you are unable to find the correct code or have any difficulty programming the AV 293 remote, you may need to consult the instruction manual or contact the manufacturer for assistance.
Posted on Jan 08, 2023
Yamaha rx-v565 wont turn on. Not "Click Sound" when Press On Button
It sounds like the output ic and or transistors have blown and need replacing. Did you short the speakers or cables?
I bought Yamaha RX V565 4yrs ago, then after 2 years, may receiver always shut off 5 minutes everytime I open. What is the problem or reason of shutting down my receiver? Thank you
press and hold both the "DIRECT" and "TONE CONTROL" buttons and press power and see what it says on the display. This will give us some idea of what is causing the receiver to turn off.
Need manufacturer's setup code for Yamaha AV Receiver RX-V373
Using 1056B03 universal remote from Time Warner. Several codes actually will turn the unit off and allow volume control. Or..I can turn on and volume control. Can't do both. I tried to use the receiver codes in the vcr mode, but the remote rejects receiver codes (i.e. only accepts vcr codes).
It looks like one or the other, not both.
Need code for Yamaha RX-V367 for Motorola DRC800 remote. Thanks!
Thank you for your question.
Yamaha RX-V367
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v367_black__u/?mode=model
Motorola DRC800
Here are a few codes to try:
0054
0030
0179
0706
How do I reset my Yamaha RX-V565 Home Theatre Receiver?
Unplug it for 10 min and plug it back in. If you need more specific help with an issue with this receiver, post a comment and I can help you further. Hope this helps.
2answers
I would like to operate a Samsung HD Cable receiver (DCB-H360R) by means of a Yamaha remote control (RAV293). I have tried all Samsung remote control codes as specifid in the Yamaha Owner Manual, but no...
Yamaha remote supports only those codes that are in the manual (they are pre-programmed in the remote), so no other code can be used. Your only option is to try codes from different brand in the manual (if not done already) or buy a universal remote, which you can program both for Samsung and Yamaha.
1helpful
3answers
My Yamaha receiver model rx-v565 audio is putting out choppy sounds when cable is playing. I am using all HDMI connections. My TV is an LG 240 Hertz model and using the comcast HDMI box.
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
1helpful
2answers
Can't set TV code on Yamaha rav293 remote
i had the same problem with the same remote but just figured it out. on the remote, to the left of the "DOCK" button, you'll see two buttons labeled "[A]" and [B] which is what you'll use as the TV source button. press the code set button, wait for it to blink two times, then press the [A] button, and press your code. VOILA! problem solved. you could also use the [B] button, but it doesn't really matter. now the tv controls work on the remote. you may have to go through all the codes for your manufacturer but eventually it should work
Open Questions:
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
