Contributor
- Posted on Jan 07, 2023
Re: How to access sponge filter on Ryobi lawn mower
To access the sponge filter on a Ryobi RM2010 electric lawn mower, follow these steps:
- Make sure the lawn mower is turned off and unplugged.
- Locate the cowl on the side of the lawn mower. This is the cover that protects the engine.
- Look for the height adjustment lever on the same side as the cowl. The sponge filter is typically located under the cowl, near the height adjustment lever.
- Lift the cowl to access the sponge filter. The cowl may be secured with clips or latches, or it may be held in place by screws.
- Once the cowl is open, you should be able to see the sponge filter. It may be held in place with a clip or other fastening device.
- Carefully remove the sponge filter from its housing and set it aside.
- Use a soft brush or a cloth to gently clean any dirt or debris from the filter. Avoid using any harsh chemicals or detergents, as these can damage the filter.
- Once the filter is clean, replace it in its housing and secure it in place.
- Close the cowl and make sure it is securely fastened.
