Question about Pioneer Audio Players & Recorders
How to reset Pioneer VSX-AX3 with no power?
Hi,i have vsx-ax3 no power.relay not clicking,i want to reset it first before going to the main board but i dont know the botton combination.can u tell me what botton is it?
Karamjeet Singh
    Novelist:
  • 63 Answers
It is not recommended to attempt to reset a device with no power. If the power is off, the device will not be able to respond to any commands or perform any actions.
If your Pioneer VSX-AX3 is not turning on or functioning properly, there are a few things you can try before attempting to reset it:
  1. Make sure the device is properly plugged in and that the outlet is functioning properly.
  2. Check the power cord for any damage, such as frayed wires or loose connections.
  3. If the device is connected to a surge protector or power strip, try plugging it directly into a wall outlet.
  4. Try a different power cord or outlet to eliminate the possibility of a problem with the cord or outlet.
If none of these steps help, you may need to have the device repaired or replaced.
Posted on Jan 08, 2023
How to reset the pioneer AV receiver vsx 932
How do I reset my Pioneer VSX 932?
While holding down [AUTO/DIRECT] on the main unit, press [STANDBY/ON] on the main unit. 2. "Clear" appears on the display and the unit returns to standby. Do not unplug the power cord until "Clear" disappears from the display.
Mar. 11, 2019
How I fixed the echo in my Pioneer VSX-932 receiver ' Benway Net
My vsx-456 clicks on but menu panel does not light up; so I don't get that volume to my tv?
Hi Cecelia, for what you say, your Pioneer VSX-456 is not working, the click you hear is the current relay and this feeds the Pioneer, obviously there is something wrong with the equipment
Consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Cecelia, por lo que comentas, tu Pioneer VSX-456, no esta funcionando, el click que escuchas es el rele de corriente y este alimenta al Pioneer, evidentemente hay algo mal en el equipo
Consulta un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/350623/Pioneer-Elite-C-72.html#product-VSX-456
https://elektrotanya.com/pioneer_vsx-456,vsx-d506s_rrv-1713_sm.pdf/download.html
No sound from Pioneer VSX-37TX
check the caps and output transistor the power ones and resistors
1helpful
I have a Pioneer VSX-515-K A/V Reciever. When I plug it in the power relay clicks continuously. I don't have the schematic to troubleshoot the circuit. I just want to make sure it is the relay that's bad...
A bad relay won't pick and release itself. You need to find the cause.
Here's the Service manual.
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-515_RRV3092.pdf
Page 66and 67 have a timing sequences for power up and down.
Pages 72 and 73 describe a possible loops - DC abnormality and Fan Stopped.
17helpful
5answers
Receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Open Questions:
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Steve
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
