Question about Yamaha Audio Players & Recorders
How can I make my screen work?
My Yamaha natural sound receiver model RX-V793 will turn on and play music but I cannot see anything on the screen?
Posted by Judy Lynn on
ADMIN Andrew
    Top Expert:
  • Yamaha Master
  • 57,419 Answers
There is normally a capacitor on the back of the display that may fail. They normally get dimmer until you can't see anything. Replacing it should fix it.
Posted on Jan 06, 2023
2answers
My Yamaha RX-V793 AV Receiver has no sound. What is the cause and can it be fixed?
(0)Download yamaha rxv793
(1)read P.10-11
(2)follow the instruction to perform self diag test
(3)or check DIR & DSP with an oscilloscope.
Right channel not working on yamaha rx v793 receiver
If the channel is dead on headphones suspect a fault in that channel. The good news is that you have the good channel to compare it with. Since the channel parts are identical. You can start with a visual check. Looking at the good and compare with the bad. Any bad looking parts should be replaced. If you are experienced with electronics you can do tests on the channel. Otherwise it is off to a repair shop with it.
All of a sudden I have no sound at all regardless of what the input is. Any thoughts or has it just died. I've had this for many years.
RX-V540 - RX-V - AV Receivers - Audio & Visual ... - Yamaha
usa.yamaha.com > ... > AV Receivers > RX-V
Yamaha CorporationRX-V540. Discontinued. Natural Sound Home Theater Receiver. 0.0. (No reviews) ...The RX-V540 is a full-featured home theater receiver ready for all formats. .... their favorite stations or to have musical genres, such as all the jazz stations,
No sound on yamaha rx-530 stereo fm receiver - Fixya
www.fixya.com/.../t25422640-no_sound_yamaha_rx_530_stereo_fm
Feb 13, 2015 - no sound on yamaha rx-530 stereo fm receiver nothing,just no soundcomming out of speakers ... Does your TV have any audio outputs such as RCA perhaps? .... Suddenly no sound is coming from my speakers except for my subwoofer. On certain settings some of the speakers work but not all of them.
2answers
EL EQUIPO SE APAGA
Can you rephrase your question in English?
1helpful
2answers
Just bought a used yamaha receiver model RXv793 do not know how to hook it up.
First do not panic by seeing all sockets in the back side of the receiver.You can connect 5 speakers and one subwoofer on the speaker A switch and maybe a second pair of stereo speakers on the B switch.All the speaker sockets have red and black terminals, so do all speakers. Just get decent cables ( You can buy a whole connection Kit if you want ) and connect the corresponding outlets to you speakers.If you have a powered subwoofer connect the subwoofer input to a socket labeled Subwoofer pre out on the RXV. You will need a RCA to RCA cable for that Next you will need a coaxial or Optic fiber cable to connect a DVD player digitally. The back of the DVD player will have a socket marked coaxial out, and so does the RXV's backside. Just link them .
Turn on the system everything should work. If you are not getting DVD sound there is small button on the RXV front panel called Digital input -- set it to auto ( keep pressing the button and it will scroll through various modes). Also remember to switch on speaker A on the front panel.
I have an old Yamaha RX-V793. It works perfectly fine. Now I have a new LCD screen, a new DVD player and my new cable tv set top box. All 3 take and use HDMI. I'd like to be able to HEAR BOTH my DVD...
hi,
u can make connections only through digital inputs(optical and coaxial). u can connect the digital outputs of ur dvd and cable set top box to the receiver. no way to connect HDMI. HDMI is a high definition media interface. for using it u have to go for a av receiver that supports HDMI.
ok
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Poor dialog sound of Yamaha RX-V363
I'm working on one right now. It seams that you are not selecting to correct program for the dialog. I would not use music enhancement on dialog content.
Open Questions:
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
