Watches Logo
John Ash Posted on Jan 06, 2023
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you set the month and date - The Watches
Bashar Telesi (TerraceDS)
Level 2:
Novelist:
  • Expert 200 Answers
  • Posted on Jan 06, 2023
Expert
Level 2:
Novelist:
Answers
200
Questions
0
Helped
40173
Points
498
To set the month and date on a device, you will need to follow the specific instructions for that device. The steps may vary depending on the type of device you are using (e.g., a computer, smartphone, digital watch, etc.) and the operating system or software it is using.
Here are a few general steps you can follow to set the month and date on a device:
  1. Locate the settings menu for the device. This is usually accessed through an icon or menu option labeled "settings," "options," or something similar.
  2. In the settings menu, look for an option related to the date and time. This option may be labeled "date and time," "clock," or something similar.
  3. Select the option to set the date and time. This will usually open a window or menu where you can enter the current month, day, and year.
  4. Use the provided fields or menus to enter the current month, day, and year. You may need to use drop-down menus or arrow buttons to navigate through the options.
  5. Once you have entered the correct month, day, and year, save your changes and exit the settings menu. The device should now be set to the correct date.
1helpful
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 • The Watches
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
7helpful
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 • Watches
How do I set the date on this watch. Can set the month, day and time but not the date.
mcdevito75 here, You may have to go thru the entire 24 hour cycle to change the date, then re-set month and day. Depending on what kind of watch you have.
Nov 19, 2010 • Watches
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
2helpful
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
2helpful
I have a jag watch j935A and need to set the month
pull the crown and stem out to the position where u set the date and spin it the opposite direction of hte date. sab is not the month but the day in spanish, you'll see
2helpful
2answers
Day and date not synchronized with actual day and date
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this solution as "fixya" or at least "helpful" as what I have said will solve your problem. :-)
Date and month
There are three positions when you unscrew the crown stem. One does the day, one does the date and one does the time. You can also advance the date by rotating the crown stem and advance the time for 24 hours, as if a day passed. That takes a lot longer.
Top The Watches Experts
vince
NOEL
NOEL
Paul Carew
Are you a The Watch Expert? Answer questions, earn points and help others
